Sharp AR-5316 Advanced Digital Imager Copier Logo
Posted on Oct 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Get F2-40 error on sharp ar-5520 Im a newbie in
Get F2-40 error on sharp ar-5520 Im a newbie in all of this. i was able to figure out how to enter to the service mode and i also tried code 14 and 16 . but still nothing happens. any suggestion what it might be?
  • walai
    walai Nov 05, 2013
    thx so
Anthony Karuku
Level 2:
  • Sharp Expert 268 Answers
  • Posted on Oct 23, 2010
Anthony Karuku
Sharp Expert
Level 2:
Answers
268
Questions
Helped
104936
Points
615
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
  1. Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
  2. Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5149
Points
Get f 2 tuner caridge repace or tuner catridge chip replace your reset code below #-int-c-int& entering the commend; core code-home-subcode-home 10 ,tonermotor operation,14 trouble cancel (except for u2) 16 ,u2trouble cancel.20, 01, maintenance counter clear ,24,07drum counter clear,25 ,oi,10 main motor check,42,01developecounter clear
amir hamza
Level 2:
  • Sharp Expert 318 Answers
  • Posted on Nov 02, 2014
amir hamza
Sharp Expert
Level 2:
Answers
318
Questions
Helped
188795
Points
694
ATC sensor abnarmality
CH blinking in sharp photo copyier model AR 5520
check if the toner is insert or check the doors for the machine both the front and side door door
2answers
HOW TO FIX ERROR CODE 444 BLINKING FOR SHARP AR-5516?
http://www.sharpmea.com/cps/rde/xbcr/documents/documents/om/34_ppc/AR5516-D-5520-D_OM_GB.pdf
Sharp ar 5516 f5 error
hi,I have error code F5 on my coppier sharp 5516. your help please.
2helpful
I have sharp AR 5316 im facing #2 or H2 error in my copier please help me and tell me what is this and what is solution for this i am waiting of your reply thank you
On a sharp machine. Press P * C * .... or # * C *. The machine should enter diagnostics mode. then enter 14 then one and press start. That should clear the issue
1helpful
F2 40 error code on Sharp 5516s copier
you must use ar-202 developer.205sd used for 5516 or 5520
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
