Can you please help me find how to restore the factory default settings on my Brother IntelliFax 2820?
Press and hold Menu and turn On fax[ MAINTENANCE MODE]PRESS 01 after beep press 99
You can try doing a reset by entering "menu/set" & "*2864" all within 2 secs. you should see "maintenance" on screen. if not, try entering code again. once in maint. mode, enter "91". should say "parameter init." enter "99" to exit. if there is a true problem, you should see some sort of code pop up.
