2003 Hummer H1 Logo
Posted on Oct 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you unlock a 2003 Hummer RDS radio reading LOC
Kevin
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 29, 2019
Kevin
Contributor
Level 1:
Answers
Questions
0
Helped
837
Points
Hold 5 and forward sip and power on
ZJ Limited
Level 3:
  • Hummer Master 17,989 Answers
  • Posted on Oct 20, 2010
ZJ Limited
Hummer Master
Level 3:
Answers
17989
Questions
0
Helped
14450247
Points
60858
About the theftlock RDS radio system.
* The theft deterrent system now utilizes class 2 serial data to determine if the radio is in the authorized vehicle.
* Each time the radio receives accessory power from the ignition, it compares the VIN information it has stored to the VIN information received from a module on the class 2 serial data circuit responsible for transmitting that information.
* If a match does not occur, the radio display will indicate "locked".
* Once this occurs the radio will not respond to operations and become inoperative.
The following conditions will enable radio lock:
* A radio is installed from another vehicle.
* A module which communicates on the class 2 serial data circuit which supplies VIN information to the radio is replaced and not properly setup with the correct VIN information for that vehicle.
To unlock radio you will need access to a GM scan tool. Hope helps (remember to rate this).
How do I unlock my radio on an 2016 Chevy equinox
Step 1: Look at your radio. Check and see if the code "RDS" is written on the face of the radio. If "RDS" is present, contact a GM dealership to have your radio unlocked by them.
Step 2: Check for the identification code. Press buttons 2 and 3 for 8-10 seconds. If a code does not appear on the display, you won't be able to unlock your radio in this manner.
[If that doesn't work vvv]
In order to obtain your radio unlock code, you need to find your radio's serial number. You can get the radio serial number directly from your radio.
Step 1: Turn on the ignition. Turn the key to "accessory" mode or "on" mode.
Step 2: Turn on the radio. Press the power button to turn on the radio.
If your radio displays any functions such as playing a CD, cassette, or a radio station, your radio is not locked. If no sound is heard, you may need to replace your radio unit.
If your radio is locked, "LOC" is displayed on the screen.
If "INOP" is displayed, keep your ignition on for 60 minutes with "INOP" on the display. After the hour is up, it should change to "LOC." After this you can proceed with the next step.
Step 3: Write down the code. Press buttons 2 and 3 at the same time and hold for 8-10 seconds. Write down the three-digit code that is displayed.
Step 4: Note down the code. Immediately press the AM/FM button. Another three-digit code is displayed. Write it down as well.
This is your six-digit radio serial number.
Now that you have your radio's serial number, you can obtain the radio unlock code from General Motors. Be ready with a pen and paper to write down your radio unlock code.
Step 1: Contact the GM radio hotline. From any landline or cell phone, call the toll-free GM Radio hotline at 1(800) 537-5140.
Step 2: Enter the code. When it requests a code, enter "106010" on the keypad, followed by the pound (#) sign.
Step 3: Enter the radio serial number. You will be prompted to enter the radio serial number you have just obtained.
At the prompt, enter the number followed by the pound sign.
Step 4: Write down the radio unlock code. The prompt will read out your four-digit radio unlock code. Write it down precisely.
Now that you've obtained your Chevrolet radio unlock code, you need to enter it into your radio.
Step 1: Switch on the radio. Turn your ignition on and press the radio power button. Your radio will display "LOC."
Step 2: Enter the first two digits of the radio unlock code. Press the hour button on the radio to enter the first two numbers of your radio unlock code.
Continue pressing the button repeatedly until the first two digits of the radio unlock code are displayed.
Step 3: Enter the last two digits of the unlock code. Press the minute button until the last two numbers of the radio unlock code are displayed.
Repeatedly press until they match the two digits you need.
Step 4: Confirm the code. When the code matches, press the AM/FM button. "SEC" will display on the radio, indicating a successful attempt to enter your radio code.
If you enter the code incorrectly eight times, the display will switch from "LOC" to "INOP." You'll need to leave the ignition on for an hour as described in Part 2 before you can retry.
Write the radio unlock code in a safe place such as in your owner's manual for future use.
Most car dealers will charge you a lot of money just to get the code for you. If you follow the right steps, you can get the code for free and be able to start listening to the radio again in just a few minutes!
How to Unlock Chevrolet Theftlock Radio
6answers
Hallo everyone Can you help me in unlocking radio FORD 5000 RDS EON in my Ford Focus serial no. M356552 PART NO.96AR-18K876-BC
Hallo everyone Can you help me in unlocking radio FORDarrow-10x10.png 5000 RDS EON in my FORD FOCUSarrow-10x10.png serial no. M440664 PART NO.98AP-18K876-BC
I have 2 Chevrolet 1500 trucks and 1 radio dont work when i swapped the radios it has LOC on the screen how can i remove the LOC? If its a code to unlock it how can i get it?
on a 2003 you have to have it unlocked at the dealer, it thinks someone tried to steal it, and doesn't recognize the vehicle its installed in
3answers
Unlock RDS Radio with the Serial Number
go to dealer supply proper docs should be free
3answers
Unlock code for 5000 rds e-o-n
call your dealer and they will be happy to supply the codes for you
2helpful
3answers
Ford 5000 RDS E-O-N radio
Hallo everyone
serial no. M058874
PART NO. 18K876-BC
[email protected] please send me to email.
7helpful
2006 gm rds radio is locked need to unlock it
I have a 6 disc AM/FM RDS Radio from a 2003 Chev Suburban that I purchased used and installed it into my 2003 Chev.Silverado and it went into lock up after I Installed it.How do I unlock it
Top Hummer Experts
ZJ Limited
ZJ Limited
ROBERT GARCIA
ROBERT GARCIA
Are you a Hummer Expert? Answer questions, earn points and help others
