SOURCE: is my tv dead?
no not at all , may be lot or h.o. transitror ar circuit dry solder, if any problem led red indicator blinks continuesly.. please chek all h.o section...and smps...
SOURCE: KV-36XBR450, FD Trinitron WEGA
Hello maymet,
This sounds like the HV protection circuit is cutting off the TV due to a high current event in the set. This could be a problem in the High Voltage section of your TV (Horizontal output transistor, Integrated High Voltage Transformer, and y of the deflection components, and or the CRT in cases of shorts).
I would suggest that if you do not have a background in electronics, you should have an experienced TV technician troubleshoot and repair this problem.
This is due to the nature of the dangerous voltages that are present in the television.
I hope this helps,
Thank you,
Shuttle83
SOURCE: TV won't turn on, delay/timer light flashing
Please update this with the blink count. That will indicate the circuit in which a problem was found. Once I have that information I should be able to give you the probable cause and remedy.
Dan
SOURCE: Sony KV-32HS420 will not come on has blinking standby light
Get out your original remote and hold the "Setup" button at the same time as holding the On/Off button on the TV set. It just worked for me!! Thank goodness. I was just about to bring it for repair but there's a snowstorm. Here's the link I got this from: http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=http--esupportsonycom-perl-tutorial-displaypltutid297templateid1regionid1KSMFlag7370&sliceId=&docTypeID=DT_TUTORIALS_1_1&dialogID=53101564&stateId=0%200%2053105132
SOURCE: sony wega trinitron won't turn on
