Question about JVC DR-MV1S DVD Recorder/VCR
Vcr will not load vcr cartridge
All
  • metoojr Jun 14, 2008
    Everytime I put in my tape, it just sits there. It will not play or anything. When you try to eject the tape, it will not come out. You have to turn it off then hit eject to get the tape to come out, the ribbon is still in the machine. I have to carefully lift it out with something.
    Novelist:
    Champion:
  • 225 Answers
The tape mechanism is not loading and/or driving the VCR tape properly. Most people don't realize that the tape is physically pulled out of the VCR cassette and wrapped around the video heads in a semi-circle configuration. Your VCR guides are pulling the tape out but not retracting it into the cassette shell when you press eject. Causes: mode switch, mechanical failure, video head speed/drive problems. All these problems are somewhat complex for a novice repair person and don't forget that new VCR's are selling for $30 at the big box stores....Glen.
Posted on Apr 30, 2009
6ya staff
SOURCE:
I insert the cartridge and the vcr spits it back out
the take up belt is worn try put the tape in hit stop then fast frwd a little bit then rewd a little then play
Aug 17, 2014 | Symphonic Televison & Video
How many motors are in the VCR section? example 1 motor for play, 1 motor for hi-speed rewind, 1 motor for hi-speed forward.
There are only 2 motors on the VCR sections.1 motor for the rewind backward and speed foward.1 motor for take in the VHS tape and eject the tape.The play button also used the same rewind backward and speed forward motor to push the film foward to the VCR play head head drums to play the tape.
Nov 24, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
When I put in a VHS, the power goes off and when I turn it back on, it ejects the tape.
It has a tape transport problem. It shuts off to avoid any damage. It probably is not loading the cassette all the way in.
Apr 21, 2010 | Sylvania DV220SL8 DVD Player/VCR
Hp 56 cartridge prints perfectly but keeps indicating problem
This is a common problem with compatible cartridges where the chip on the cartridge is faulty, missing or is not making contact correctly with the printer cartridge connectors. The first thing to do is make sure that the plastic seal has been removed from the chip and that it is free of any residual adhesive etc. You can clean this with a cotton bud soaked in isopropyl alcohol or VCR tape head cleaner. DO NOT USE SURGICAL SPIRIT or any other cleanser as this will either leave a residue itself or damage the plastics and rubbers in the printer.
Once cleaned reinsert the cartridge and try again. If this is still unsuccessful the best solution is to return the cartridges to the vendor where you bought them and get another brand of cartridges or use genuine original cartridges. When you find a reliable manufacturer of cartridges, stay with them. Don’t forget to clean the print head and realign & recalibrate the printer at every cartridge change for optimum results. Also make sure that you use high quality paper for the best images results.
If you have colour or photo paper loaded in the Main tray when you align the printer, the alignment might fail. Load unused plain white letter or A4 paper into the Main tray, and then try the alignment again. If the alignment fails again, you might have a defective sensor or ink cartridge.
Oct 03, 2009 | HP DeskJet 5650 InkJet Printer
Printer doesn't work after putting in a new color cartridge.
Oct 03, 2009 | HP DeskJet 5740 InkJet Photo Printer
Installed new ink cartridges but printer has not recognised this and is still looking for cartridges to be installed
Oct 01, 2009 | HP - HP Photosmart 8250 printer
VCR Problem
your cassette may be too stuck & strong for the vcr to load. or check if the vcr set of driving & loading belts are not slack
Oct 12, 2008 | Samsung DVD-V1000 DVD Player/VCR
Tape stuck in VCR
could be that you're looking at a blown cartridge for that vcr tape. You may need to cut the tape, to extract that from the unit.
The play head would usually retract when the cartridge is removed, BUT could be compromised by some tape getting into the play head mechanism, and jamming.
be particularly careful with anything pointy or sharp, as the tape head does NOT like those objects near the read surface.
Mar 02, 2008 | Philips CCC132AT 13 in. TV/VCR Combo
VCR kicks out cassettes
Sounds as if something got bent in the loading mechanism when you freed the stuck tape. Careful examination of the loading operation with the cover off may reveal the problem, but you may require a service shop, as there are hazardous voltages present inside, even when switched off.
Jul 13, 2007 | Toshiba MW24F52 24" TV/VCR/DVD Combo
VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Jul 09, 2007 | Mitsubishi HS-U781 S-VHS VCR
JVC DR-MV1S DVD Recorder/VCR Logo
239 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
