Replacement fuel lines should be readily available at your local lawnmower repair shop. Your TroyBilt hedger uses fuel line that is 3/32" (2.4mm) interior dimension, 3/16" (4.8mm) outside dimension, with a 3/64" (1.2mm) wall dimension.
Most manufacturers don't offer replacement line, only fuel tank assemblies. Find your local shop, and try to get the TYGON brand...it is yellow. Tygon lasts the longest. You should be able to buy it by the foot for less than $2 per foot. You will need 2 feet of hose to replace both lines.
Make sure to clean the in-tank filter when replacing hoses.
Good luck.
