SOURCE: HTC messaging disappeared
I had this problem ,also no notifications of voicemail as well as not being able to acces the messaging screen. I was just about to send the handset in for repair and decided to remove the 4gb micro sd card .turned the phone off ,removed the card,turned it on again ,bam messaging works again !! hope this can help someone else too :-)
SOURCE: HOw to turn off the voicemail notification?
you will need to give more info on the type of phone you have.....
SOURCE: Notification alert for calendar items on Samsung i780
Hi there!
Try to click the bell icon when you set your alarm and see if you have checked the box for "play sound".
Also, verify if your volume is up and not in "Off" mode.
Also, go to Settings, click Sounds and Notifications. Verify if you were able to check the "Enable sounds for programs" box and make sure the notifications box is checked.
And on the notifications tab select "Reminders" from the drop down menu for "Event" and ensure that "Play sound" and "repeat" are checked.
Hope this will solve your problem!
