In addition to clearing memory this *will reset unit to factory defaults.
*****all of your programmed settings will be erased.
First power down the fax by unplugging, then power on.
After the power is turned on and "WAIT A MOMENT" is displayed, press & hold the STOP key.....until a normal display message shows.
*The above step allows the memory to be cleared! If this step is skipped clearing memory to factory defaults, (below) may not always work.
Press the "function" key followed by ALL of the following
9 * 8 # 7
wait until "diag mode" is showing.
Then press start button, followed by either * or #
until "memory clear" message is displayed.
then press start. If stressful "memory cleared" is shown.
proceed to re-program your fax machine settings.
SOURCE: How do I erase the memory from my Sharp UX B700 Plain Paper Inkjet Fax
chose from setup menu on fax erase document in memory or etc.
Don't worry about the memory being full, the problem is the ink, and once the machine is able to print the FAX will empty memory by printing the faxes out. This might sound bad but I have seen this happen, when you unpacked the new ink cartridge, did you pull off the little plastic protector? And is the paper loaded?
