SOURCE: zanussi oven wont work. clock flashing 'auto'
you need to set clock before oven will work. do you still have instruction book as it will tell you there how to do it
SOURCE: clock on cooker flashing
Excellent! Now my clock works, but where can I get an instruction booklet for this oven? Thanks.
SOURCE: tricity bendix double oven
My oven's fan is working but no heat what so ever what shall i do
SOURCE: Baumatic Oven - Setting the Clock/timer after power has been off.
Hi, You press the second and third button in together, hold them in and use the + or - buttons to set the time.
SOURCE: main oven wont work because
Hello, Thank You for using FixYa. I will be helping you today.Without model number its a little harder to figure out but lets give it a try.Did you press cancel or off? If this doesnt work unplug the unit for five minutes and dont cheat five minutes or turn the breaker off. After five minutes if the control still says the same thing chances are you have a stuck or shorted keypad,Which would have to be replaced.
Thank You and please rate my answer if it was helpful..
