I have removed the 8 screws holding the case together and can't figure out how to separate the front from the back. It acts like it's glued together. Can you off some idea as to how to get inside the radio?
The radio works fine, but the charger doesn't work. I'm assuming that it's just the fuse.
Thanks
I had the same problem with the case not coming apart after I took the screws off, but thanks to someone posting a suggestion on this website, I was able to take it apart and take care of the problem. Use a soft mallet and use it around the seam of the radio until it pops loose.
By the way, my original problem with the radio was that it would not get any power at all, whether using the power cord, or an 18v battery. I was able to fix the problem by replacing the fuse located inside the case (250v / 1AMP)......works great now!! Many thanks to all of you who posted suggestions on this great website!!
Remove 2 screws on metal front cover.
Remove screws holding handle halves together and carefully separate (Be careful because trigger spring can fly out on you).
This will expose the belt and allow replacement. There is a spring loaded idler pulley so removal & replacing is easy.
Hi there, Remove the battery and sometimes the screws on the drill casing are a torx instead of phillips so you will need a set of torx screwdrivers. Once you have removed the screws from the casing be very carefull when pulling the two casings apart, try to leave the chuck, motor and switch assembly in one half of the casing as it makes it much easier when trying to put it back together.
I hope I can help, It doesn't open from the back, it opens from the front.... carefully! There are four support screws, which hold the LCD screen to the desk stand,after removing all the support screws (4) on the back under the support stand cover.(which pull up to remove) (Remember! the whole case and face frame is plastic, so take your time). Work to separate the black face frame around the LCD from the silver case. Its held together by small plastic clips on the face frame to the wall on the LCD case. Start at one of the corners and slowly pry the face frame and silver case apart. (separate it inch by inch, work your way around the case carefully. If one corner doesn't give, go to another side.
Putting back together works reverse, the face frame and the case snap back together, Carefully! And replace screws (4).
Russell
P.S. I have three LCD models from Westinghouse, LCM-22w2, L2210NW and the L1916HW. They all open the same way.
There was a fuse inside - Replaceable - fixed the problem.
There were no hidden screws, none under stickers or in the battery box like suggested by others, and the 2 magic release screws not so. There are several deep screws requiring a long philips, but the entire seam is glued (why?) so to open the radio I had to hit the body near the seam with a rubber hammer to crack the seam loose once all the screws were removed, comes right apart. Put it back together without glue, just the screws, it will be fine.
Great solution!!! Thanks
