Hi i got your issue
Try with the following steps ....
Step 1:Connect modem>>Router>>Computer
Step 2: Open the browser page and on the address bar type http://192.168.2.1
Step 3: Towards the left column below firewall click on virtual servers
Step 4: It will ask you for the password just leave it blank and hit submit
Step 5: Check whether any ports have been opened
Step 6: If not contact your x-box vendor and get the port numbers and the ip address of the x-box
Step 7: Come back to this page and enter all those numbers and click on apply changes
Step 8: I will give you an example how the numbers has to installed
Step 9: On description type -x-box ..
And on inbound port-enter the port number(as given by the x-box vendor)
And on thye it can be TCP OR UDP OR BOTH
Private is as same as that of the inbound port
Ip address is the ip address of the x-box
Step 10: Open all the port numbers and click on apply changes
Step 11: Towards the left column click on firewall and then disable it click on apply changes
Step 12: Hopefully this will work
If you any issues let me know or contact the 24/7 Belkin technical support 1800-2235546
Thanks .....
With regards....
Priya
Once
you have all the wireless settings of the router, you are ready to
connect the play station or the x-box to the wireless network.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select
the name (SSID) of your wireless network. If your router isn't
broadcasting your network's name, select Specify Unlisted Network and
enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Trouble connecting to the internet on X-box ,Play station or WII ?
You
can try to reduce the MTU settings on the router. if the MTU on the
router is set to 1500 then change the MTU to 1365. Also you will need to
open the ports on the router.
For X-box port numbers are - 53, 80-88, 3074 .
