Onkyo TX-SR605 Receiver Logo
Posted on Oct 19, 2010
Cannot find code to set my cable remote to turn on/off my receiver
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3088
Points
5
The Remote Code 1789 will both turn ON and also turn OFF the Onkyo TX-SR605 AV/Receiver. Many codes will either turn it on or turn it off, but not both. Code 1789 will do both.
I need codes for a Yamaha rx-v2500 receiver. The codes listed turn it on but not off. Can you help??
Joseph, codes 0081,0082,0176, 0186, 1176, the attached manual may have more codes.
Yamaha rx-v2500 receiver, try the auto programming feature on your remote to set up universal remote. It is possible the remote may not support your equipment and you will have to replace with compatible remote. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Yamaha RX V2500 Receiver and DVR PVR 5 HELP
Codes for Universal Remotes Codes for Universal Remotes How to Program Universal Remote
Yamaha RX V2500 Owner Manual Setting Remote Control Codes
Can i use an Onn Universal remote for a Suddenlink cable receiver?
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Try the set-up codes for Suddenlink cable box. If you can't find any code there, try a code-search procedure.
2helpful
Cable remote AND vizio tv remote will not turn on the tv
We will presume you do not have two bad remotes---the fact you can operate the set manually with the buttons there suggests a problem with the remote receiver====there is a tiny infrared receiver in the front of the set that receives the signals from the remote and sends them inside the set where the correct action is taken.
Make sure if you see it (usually small black area on frame of set) it is not blocked or dirty.
Failing that you may have a bad receiver for the remote---shop repair.
1helpful
How do I set my comcast cable remote to the Kenwood cs 5.1 receiver?
These codes may work:
Depending on the comcast model remote you have: Some require the full 5 digit code while others only use the last four digits.
Codes for Kenwood receivers:
31313 31571 30027 31007
Most Direct, Comcast and COX remotes use the same basic codes either with or without the first digit which is always a 0,1, 2, or 3. (0 for cable boxes, 1 for TVs, 2 for DVDs, 3 for audio amps and receivers)
Hope this helps.
My cable tv remote will turn this unit on with the codes supplied for the remote. But the remote will not control the volume or turn the unit off. Is there another code, or is this a problem with the cable...
There has to be another code and when you find it you will probably have to "lock" your remotes volume control to your audio device not the cable box (set-up that way from cable co) once you do that the cable box will be controlled from the remote(channels) and the audio will be controlled by your receiver from the same remote without even having to switch functions.. ask your cable company for a setup guide for your remote they will probably have a copy online.
5helpful
I need the RCA remote code for Durabrand tv
Since the Funai code does not work, you have to use the CODE SEARCH feature.
The remote may already be set up to operate your brand of TV, VCR, Laserdisc, Satellite Receiver, Audio Equipment, or Cable Box. It is pre-programmed with the following codes: TV-000, VCR1-000, AUDIO-003, and SAT•Cable Box-000. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using CODE SEARCH
1. Manually turn on your device (TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box or Audio Equipment).
2. Press and hold CODE•SRCH.
3. Press and release the device button you want to set up (TV, VCR1, VCR2•LD, SAT•CABLE, or AUDIO).
4. Release CODE•SRCH.
5. Press POWER repeatedly until the device turns off (you may have to press up to
100 times).
6. Once the device turns off, press and release ENTER.
7. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond,
repeat steps 1-7.
Programming Your Universal Remote
20helpful
3answers
Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
It took me a week to find the right instructions and codes on how to do this so I am posting it everywhere I can to help out folks with the same remote. Pay close attention to the instructions, for instance when programming the remote for TV use make sure you hold the TV button down while you enter the code and then press OK, You also have to hold the TV button down while you use the volume and channel controls or it will just change the VCR channel.
A
Turn on TV
Turn on the TV using the Power button on the TV or its Remote.
B
Set TV brand code
A
Press and hold TV.
B
Press MBR SET.
C
Press the Number keys to enter your TV.s brand code.
D
Press OK, and release TV. The TV should turn off.
C
Operate TV
While holding down TV, press one of the following buttons:
POWER 1, TV/VCR, TV CH+/., ^(TV Muting), TV VOL+/.,
and the Number keys.
For some brands, you must press ENTER after having pressed the
Number keys to enter a channel number.
TV BRAND CODE TV BRAND CODE
JVC 01, 03
SONY 07
HITACHI 10
SAMSUNG 12
MAGNAVOX 02
SANYO 13
MITSUBISHI 03
SEARS 13
PANASONIC 04, 11
TOSHIBA 08
RCA 05
ZENITH 09
SHARP 06
Cable Box or DBS Receiver Brand Setting
A
Turn on cable box or DBS receiver
Turn on the cable box or DBS receiver using the Power button on
the unit or its Remote.
B
Enter brand code
A
Press and hold CABLE/DBS.
B
Press MBR SET.
C
Press the Number keys to enter your cable box.s (or DBS
receiver.s) brand code.
D
Press OK, and release CABLE/DBS.
C
Operate cable box or DBS receiver
While holding down CABLE/DBS, press one of the following
buttons: POWER 1, TV CH+/., and the Number keys.
To change the cable box.s (or DBS receiver.s) channels, press TV
CH+/–
or the Number keys. (The CH+/–
button can be used to
change the VCR.s channels only.)
CABLE BOX BRAND CODE
ARCHER 01, 05, 17
CABLETENNA 01, 17
CABLEVIEW 15, 16, 17, 21, 25
CITIZEN 15, 16, 17, 21, 25
CURTIS 02
DIAMOND 01, 17
GC BRAND 15, 16, 17, 21, 25
GEMINI 15
GENERAL INSTRUMENTS 01, 04, 06, 11, 12, 15, 28
HAMLIN 10, 18, 23
JASCO 15
JERROLD 01, 04, 06, 11, 12, 15, 28
NOVAVISION 02
OAK 07
PANASONIC 13, 14
PULSER 15, 16, 17, 21, 25
RCA 13, 14
REGAL 10, 18, 23
REMBRANDT 01, 16, 17
SAMSUNG 05, 16, 24
SCIENTIFIC ATLANTA 02
SIGMA 07
SL MARX 05, 16, 17, 24, 25
SPRUCER 13, 14
STARGATE 05, 15, 16, 17, 21, 24, 25
TELEVIEW 05, 16, 24
TOCOM 01, 04, 16
UNIKA 01, 17
UNIVERSAL 16, 17, 25
VIDEOWAY 03, 09, 22
ZENITH 03, 09, 22
DBS RECEIVER BRAND CODE
JVC (DISH Network) 51
ECHOSTAR (DISH Network) 51
SONY (DSS) 41
RCA (DSS) 40
Changing Remote Control Code
This Remote is capable of transmitting two control codes; one set
to respond to A code control signals and another set to respond to
B code control signals. This Remote control is preset to send A
code signals because your VCR is initially set to respond to A code
signals. You can easily modify your VCR and the Remote to
respond to B code signals. When using two JVC VCRs, set two
VCRs and their Remotes to different codes, so that you can
operate these VCRs separately.
A
Set remote control code for Remote
A
Press and hold A/B.
B
Press the Number key .2..
C
Press OK, and release A/B.
The Remote now can transmit B code control signals.
B
Check remote control code for VCR
Press and hold 4
on the VCR for more than 5 seconds while the
VCR is turned off. The code currently set appears on the display
panel.
C
Change code for VCR
Press any key on the Remote. The VCR now responds to B code
control signals.
To set the Remote and the VCR back to A code control signals,
repeat the same procedure as shown above except pressing the
Number key .1”
in step B
of 1
1111.
To control two VCRs with the same Remote
You can control two JVC VCRs by switching the remote control
code for the Remote between A and B (.
step A
AAAA), keeping two
VCRs to different control codes.
To change only the remote control code for the Remote, DO
NOT perform steps B
BBBBand C
CCCC.
Question about what the code is for the receiver?
you are trying to turn off a yamaha system with your cable remote?
18helpful
3answers
CORRECT SETUP CODE FOR RECEIVER
Originally Posted by 3FingeredGlove viewpost.gif We can make this work. You didn't mention which setup code you're using, or explicitly say whether the OK/Select button is red or gray (the manual you're using is for gray), so these are somewhat generic instructions. Should work, though. This will provide a power toggle function to the Power key.
Use red numbers for the red OK/Select button remote, grey numbers for grey button remtoes.
Temporarily assign setup code 30842 or 0842 to AUX
1) Tap AUX
2) Press Setup until 2 blinks
3) Enter 30842 or 0842The remote should blink twice
Assign NEC1 IR protocol device 210, subdevice 108, function number 203 to Power (you don't need to understand these numbers)
1) Press Setup until 2 blinks
2) Enter 994 (2 blinks)
3) Tap Setup
4) Enter 00051
5) Tap Power (not All On)
Assign setup code 30135 or 0135 to AUX (this is NEC1, 210.109)
1) Tap AUX
3) Enter 30135 or 0135
3answers
that is because i think that your reciever would have its own code
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
