Toshiba Satellite R10-S802TD Tablet PC Logo
Anonymous Posted on Oct 19, 2010
I just bought new lcd display for my Toshiba Satellite R10 Tablet. The inverter is fine, checked the cables and reconnected. But the screen alternately flashes solid white, red, green and blue on the screen.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 30, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
476
Points
You need to download the proper drivers for the Graphics Card Right click your desktop go to settings go advanced Go to the intel(R) tab and hit Graphics Properties thin pick' either Dual Display Clone or Extended Desktop and Click Apply.
Wierdly the Monitor 2 will Still he greyed out in the settings Tab but the monitor will display Good luck
I'm currently trying to figure out it I Can Rotate the tablet Monitor and keep the other monitor Un-rotated Any ideas?
My young son leaned on my toshiba portege m200 when it was closed. The monitor stopped working. I bought a used screen on ebay that was purported to work. I removed the screen and installed the new...
If an external monitor showed graphics, then there is nothing wrong with your Graphics 'chip'.
{'Chip' is a slang term for IC. Integrated Circuit.
The Integrated Circuit for graphics is a GPU. Graphics Processing Unit. Your laptop uses the Nvidia GeForce G0 FX5200 GPU.
Your laptop like many others, does not have a graphics adapter card. It has Integrated Graphics. Another term is 'OnBoard'.
The graphics chip is on the board.
Motherboard.
There is no graphics adapter card to remove, and replace}
Some areas you may wish to address:
1.The Native Resolution is 1400 X 1050. What does it state in Display Properties?
(Right-click on any empty area of your desktop screen.
Click on Properties at the bottom of the list.
Click on the Settings tab)
2.There are known issues with the CMI display cable. Observe the display cable. Look at the letter/numbers under the barcode. Does it start with CMI?
3.There have been known issues with the connectors on digitizer cable
http://www.irisvista.com/tech/laptops/ToshibaM200/Portege_M200_digitizer_2.htm
(The above is for reference to the digitizer cable identification)
How to enable the touch screen on my toshiba satelite r10
you need the wacom touch screen driver, just go to wacom .com and all i did was download and installed the driver, i run win xp , not tablet version, and after the driver ws installed the table an pen worked 100%,
Clean dust from tablet pc screen
I have an R10 tablet.
I once asked a Toshiba certified technician if I could remove the screen cover and I was told that I am not supposed to do that.
Maybe you shoul take the unit to a Toshiba repair center in your town, or country.
Hope it helps.
Toshiba satellite 1115-S103 I can't boot up
It seems like your computer is booting from the network. This means that it is not detecting the Hard Drive. This error shows up when the hard drive is already busted or is not working anymore. You'll need to call toshiba for repairs or just get a brand new hard drive and install it yourself. It's pretty simple.
Toshiba R10
it might seem that the other user has a limited account and maybe the driver of the pen function is limited only to the administrator.
Rusty;
Hallel Computer Enterprise
baguio city philippines
1helpful
Problem with my tablet pc
Hi
The Satellite R10-S802TD doesn't have built in bluetooth device, however it's bluetooth compatible. any external bluetooth adapter will work. Toshiba recommends
PA3370U-1BTM Toshiba Bluetooth SD Card V1.2 or
PA3405U-1BTM Toshiba Bluetooth USB adapter as indicated you product's spec sheet.
Please post if you need further assistance.
Good Luck
1helpful
2answers
Display problem in Toshiba Satellite pro L20
did you try the FN and F8 key and try that see if that turns the lcd on. If not write back here and we can figure it out.
Top Toshiba Tablets & eReaders Experts
k24674
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
