SWITCH IGNITION ON WITH ENGINE OFF.PRESS SMALL ROUND BUTTON ON LOWER RIGHT OF THE SPEEDOMETER UNTIL IT DISPLAY ODOMETER.THEN TURN OFF IGNITION SWITCH OFF.PRESS AND HOLD SAME ROUND BUTTON LOWER RIGHT SPEEDOMETER TURN IGNITION TO ON WITH ENGINE OFF.CONTINUE TO HOLD BUTTON FOR AT LEAST 5 SECONDS UNTIL IT DISPLAY INDICATES 000000 AND MAINT REQUIRED LAMP WILL EXTINGUISH.RESETTING IS COMPLETE.
Oil Change Reset Procedure
Step 1.
Switch display to the odometer.
Step 2.
Turn the "ENGINE START STOP" switch or the engine switch OFF.
Step 3.
Vehicles with the smart key system: While pressing the
trip meter reset button, turn the "ENGINE START STOP" switch to IGNITION
ON mode. Continue to press and hold the button until the trip meter
displays 000000.
Vehicles without the smart key system: While pressing the trip meter
reset button, turn the engine switch to the "ON" position. Continue to
press and hold the button until the trip meter displays 000000.
Navigation Maintenance Item Data (If equipped)
This system has a function which informs you of the time to replace
certain parts or components as well as other information shown on the
screen. When the system begins operating after reaching either the
information items date or driving distance, the "information" screen
will be displayed.
To avoid seeing the "information" screen again, touch the "Do not display this message again" switch.
Setting Maintenance Information
Date: Input the next maintenance date.
Distance: Input the driving distance until the next maintenance check. You can input up to five digits for the driving distance.
When you touch the "!" switch on the screen, the screen changes
to display the "Change name" screen. Touch the keys to input your
desired name and then input the conditions.
After you input the information, touch the "OK" switch. The screen
returns to the "Maintenance" screen. The icon color will change to green
after the date and driving distance are input. The icon color will
change to orange when your vehicle needs to be serviced. The following
switches appear on the "Maintenance" screen.
Touch the "OFF" switch on the "Maintenance" screen, and the "Information" screen will no longer be displayed.
Note:
I know on chevy silverado you can turn the key on and pump the gas pedal like 8 times then start it and your like check engine light and stuff goes away but it will come back on so many days later and you just have to do it again or just bring it to the shop and they should be able to take it off idk how much that would cost you
SOURCE: How do i reset the maintenance required light
1. Turn the ignition key to the “OFF” position
with the odometer reading shown.
(For details, see “Odometer and two
trip meters” on page 145 in this Section.)
2. Turn the ignition key to the “ON” position
while holding down the trip meter
reset knob.
Hold down the knob for at least 5
seconds. The odometer indicates “000000”
and the light goes off.
If the system fails to reset, the light will
continue flashing.
To reset the Maintenance Lamp turn the car key to ON (not start), set your odometer on mileage (not trip a or b), then depress and hold the button that switches from odo and trip then turn key off. Turn the key back to ON, while you are holding the button down you will notice the maintenance light blink and go out. Reset is complete and you are done.
These are available in your owners manual for the vehicle.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: reset maintenance required light on 2009 corolla
1.Turn the "ENGINE START/ STOP" switch or engine switch OFF with the trip meter A reading shown.
2.While pressing the trip meter reset button, P.138 turn the "ENGINE START/ STOP" switch or engine switch ON.
3.Continue to press and hold the button until the trip meter displays 000000.
Don't flame on me if you don't understand what i typed. This is word by word out of the 2009 toyota corolla owners manual page 315. Hope this helps.
