Setting Olevia 323 TV picture i.e., color temp, tint, etc
  • marc paul bloome Oct 19, 2010
    Tried and this is what I got. Bad Request (Invalid Hostname). AND, my model is not a 323V. Moreover, finding that manual from another source, the manual does not explain how or even mention the OSD "lock":.
    Model - Olevia 323-S11. Not 323V.
    unlocking OSD AND SETTING VIDEO. Open with Menu, and then, go to Picture. Per instructions, down arrow to Color Temp. Cannot get to anything beyond that. In Color Temp. should be able to use up/down arrows to select 6500 or...Nothing. No movement whatsoever. Same with any other item, Mode, etc. Once in Picture/Color Temp(or anything else)no instructions can be input. It is as if OSD process IS "LOCKED".
  • 11,896 Answers
You can download the entire manual for free here if you need it:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
This will describe the step by step procedures to go into your menu settings, find the picture settings, then adjusting them.
Posted on Oct 19, 2010
  • 6,993 Answers
what you will be needing is the manual for your TV. The manual will explain better.
In case you don't have the manual, visit the below link, and click "View/Download", wait a while till the download completes. Go to display settings area of the manual and you will get detailed info about the your TV's display/picture settings.
http://www.manualnguide.com/manual-get/7939/
Good luck.
Posted on Oct 18, 2010
What are the picture settings for a TC-P55ST30 3D TV?
You can make your own settings in user 1 or you can use default settings such as sport, cinema, game etc.
Nov 12, 2011 | Televison & Video
My philips dvp3560 will only playback in black and white
Check the TV System menu:
[TV System]
Change this setting if the video does not appear
correctly. By default, this setting matches the most
common setting for TVs in your country.
• [PAL] - For a PAL-system TV. (European TVs)
• [Multi] - For TV that is compatible with both
PAL and NTSC.
• [NTSC] - For an NTSC-system TV. (American TVs)
Also try:
[Picture Setting]
Select a predefined set of picture color settings or
customize the personal setting.
• [Standard] - Original color setting.
• [Bright] - Vibrant color setting.
• [Soft] - Warm color setting.
• [Personal] - Customize the color setting. Set
the level of brightness, contrast, tint and color
saturation, then press OK
Mar 05, 2011 | Philips DVP3560 DVD Player
Red Tint on Screen
This is normal and is a color calibration issue.
For correct color, NEVER use the "WARM" setting. Why? Too red. You cannot get REALISTIC or ACCURATE color using the "Warm" setting.
Since we are speaking of Samsung, first avoid the "Flesh Tone" adjustment. When things are set correctly there is no need for this adjustment. It is a quick fix and not for the "discerning eye".
1. First, access the "Color Temperature" menu. From here select "Cool2" or the coolest temperature setting.
Note: For Samsung use "Cool2", or if not available, "Cool1". Samsung has inadvertently increased calibration confusion by issueing TVs that have just "Cool1", and TVs that have both "Cool1" and "Cool2" :0[
For other brands, use "Cool", or "High", or "+6500k". Anything lower artificially reddens the picture and compromises detail.
2. Now return to the color settings and reduce "Color" to between 30 and 40 (on a 100 scale). The sweet spot is just near the place where the color rapidly washes out.
3. To round out the color palette, move to the "Tint" adjustment and ADD a couple (3-5) clicks to the GREEN.
Adding the touch of green is what is needed to take out the last bit of "pink" and will make all the tones and all colors display properly.
I hope this helps!
To further increase the quality of your picture visit
http://www.wowvision.tv/main.htm
Highdefjeff :0]
Jun 15, 2010 | Samsung LN46C630 TV
I have sound but no picture on my Olevia tv, model 323-S11
this sounds like a mainboard issue , a replacement mainboard will solve this problem
Apr 23, 2010 | Olevia Kolin DLT2711M 27 in. LCD...
Adjusting color/ user mode??
The TV will not let you set brightness, contrast, color or tint in the preset modes like Vivid, Movie, Standard etc. Look for a mode that says custom, user etc..
Nov 11, 2009 | Olevia LT42HVi 42 in. LCD Television
I can't seem to correct a tint problem. The tv turns on and the tint doesn't change. A friend says it could be a vidoe card?
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
Nov 08, 2009 | Akai PDP4225M 42 in. Plasma Television
Unlock Olevia remote control
Why are the menu settings that I changed not being saved? A. The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***
Nov 14, 2008 | Olevia LT42HVi 42 in. LCD Television
Image tinted blue, washed out.
use voltsmeter to test ur unit power output voltages & check for swollen or burst fillter or electrolytic capacitor in the power board
Nov 10, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 540
My tv is crap to. Green tint and washed out colors. Mine is 13 mos old. and the first one they sent had green tint to. They sent another one but now Im past warrantee! Ill never buy another tv or anything from them again!!!
Feb 09, 2008 | Olevia LT42HVi 42 in. LCD Television
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
