Question about Dell Dimension 3000 PC Desktop
I get beeping when I start the computer, and it wont start?
  • 340 Answers
This is called a beep code. It is used for troubleshooting when you are unable to boot your computer. Here is a listing of the Dell beep codes, depending on the sequence of beeps that you are hearing, you will find the problem listed here. How many beeps are you getting and what model of Dell do you have?
1-1-2 Processor Register Failure 1-1-3 NVRam 1-1-4 ROM Bios checksum failure 1-2-1 Programmable Interval Timer 1-2-2 DMA Initialization Failure 1-2-3 Direct Memory Access Page Register Read/Write Failure 1-3-1 - 2-4-4 Memory/RAM Not Properly Identified or Used 3-1-1 Slave DMA Registration Failure 3-1-2 Master DMA Registration Failure 3-1-3 Master Interrupt Mask Registration Failure 3-1-4 Slave Interrupt Mask Registration Failure 3-2-2 Interrupted Vector Loading Failure 3-2-4 Keyboard Controller (Input) Test Failure 3-3-1 NVRam Insufficient Power 3-3-2 Improperly configured NVRam 3-3-4 Video Memory(RAM) Test Failure 3-4-1 Screen Output Initialization Failure 3-4-2 Screen Retrace Failure 3-4-3 Failure Finding Video Read Only Memory 4-2-1 Lack of Time Tick 4-2-2 Shutdown Failure 4-2-3 Failure in Gate A20 4-2-4 Unexpected Interruption in Protect Mode 4-3-1 Memory Address Failure above 0FFFFH 4-3-4 Non Functioning Time Of Day Clock 4-4-1 Serial And/Or Parallel Port Test Failure 4-4-4 Cache Test Failure
http://www.bioscentral.com/postcodes/dellbios.htm 1-1-2 Processor Register Failure 1-1-3 NVRam 1-1-4 ROM Bios checksum failure 1-2-1 Programmable Interval Timer 1-2-2 DMA Initialization Failure 1-2-3 Direct Memory Access Page Register Read/Write Failure 1-3-1 - 2-4-4 Memory/RAM Not Properly Identified or Used 3-1-1 Slave DMA Registration Failure 3-1-2 Master DMA Registration Failure 3-1-3 Master Interrupt Mask Registration Failure 3-1-4 Slave Interrupt Mask Registration Failure 3-2-2 Interrupted Vector Loading Failure 3-2-4 Keyboard Controller (Input) Test Failure 3-3-1 NVRam Insufficient Power 3-3-2 Improperly configured NVRam 3-3-4 Video Memory(RAM) Test Failure 3-4-1 Screen Output Initialization Failure 3-4-2 Screen Retrace Failure 3-4-3 Failure Finding Video Read Only Memory 4-2-1 Lack of Time Tick 4-2-2 Shutdown Failure 4-2-3 Failure in Gate A20 4-2-4 Unexpected Interruption in Protect Mode 4-3-1 Memory Address Failure above 0FFFFH 4-3-4 Non Functioning Time Of Day Clock 4-4-1 Serial And/Or Parallel Port Test Failure 4-4-4 Cache Test Failure
Posted on Oct 18, 2010
  • Dell Master
  • 5,660 Answers
The beeping you hear is a BIOS Beep Code.
The computer's way of telling you something is wrong, and an area to look in for the problem.
The beep code is just that. A Code.
It can be a single beep, or a series of beeps.
The beeps can alternate.
For example: One Long beep followed by two Short beeps. Then a pause of time, and the code starts all over. This is repeated over, and over.
The BIOS Beep Code may tell you something's wrong with the graphics, or the Processor, or Ram Memory, and so on.
Without knowing the beep code you're hearing, I can only supply generic information.
http://www.5starsupport.com/info/beep_codes.htm
The above shows charts of BIOS Beep Codes from a lot of BIOS manufacturer's. There are only three main one's.
AMI, Phoenix, and Award.
(Award and Phoenix merged, but sometimes still show themselves as two separate entities)
I would like you to look into an area that seems to crop up a lot.
The Ram Memory.
A ram memory module ('Stick') will develop corrosion on the contact pins.
The gold plated contact pins on the bottom of the ram memory module.
Example showing a DDR Sdram ram memory module, of the contact pins stated above,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(You can click on the photo to enlarge. You can enlarge twice)
I would like you to remove your ram memory module/s, and clean the contact pins on both sides, with a pencil eraser.
If you are using a pencil, and not a solid eraser, refrain from letting the metal band on the pencil hit the contact pins.
NOTE*
Before you start;
1) Computer unplugged from power
2) Follow Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit) the hardware components inside a computer.
(Some examples: Processor, Ram Memory, Harddrive, Graphics Card {If used)
Computer on a table, computer unplugged from power, computer case open,
TOUCH the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, upon your return be SURE to Touch the metal frame again.
If this problem does indeed relate to a Dell Dimension 3000 desktop computer, here is the Service Manual,
(Free from Dell Support),
http://support.dell.com/support/edocs/systems/dim3000/en/SM/index.htm
1) Removing the Computer Cover
2) Removing and Installing Parts > Memory
Regards,
joecoolvette
6ya staff
SOURCE:
My computer is beeping and wont start
try checking the ram,check the fan is running,check hdd,
give all a good clean up.
Apr 27, 2014 | Gateway GM5472 PC Desktop
Computer starts to power up, two beeps then nothing and wont come on
severe virous you may need to format and reinstall all softwear.
Sep 18, 2012 | Gateway One Computers & Internet
My PC wont start up, all it does is beep constantly. I don't have any idea what to do. Please can you help?
Beeping when the computer first starts up indicates a hardware failure. It can be bad memory, bad motherboard or something else is bad.
You can look up the beep codes from your computer manufacturer's website under support or Google It.
If you are not able to replace memory or motherboard on your computer, You will need to have a computer tech look at your computer.
Sep 30, 2010 | Computers & Internet
Computer wont start.
I don't have access to your board details. However, beeps frequently represent memory problems. Try
removing the memory on your system and then putting it back.
You can access your memory on the bottom of your computer. It is likely the smallest rectangular hatch. After powering donwn the computer, remove one or two screws.
Remove the memory sticks by spreading the clips on each side of the memory. After removing them, put them back. This will clean the terminals and ensure a good connection. Before putting the back on, try to boot the computer. If you hear no beeps, all is good. Turn off the computer and put the hatch back on.
If you hear beeps, switch the memory modules. Try again. If you still hear beeps, try one module at a time in the primary memory slot. If one of these works, you should be able to buy a new memory module. Go to a sight like Crucial's and have it tell you what you can add. Perhaps this is a good excuse to upgrade.
You should do this at the kitchen table to avoid any static discharge.
May 20, 2010 | Fujitsu Siemens Lifebook N5010 Notebook
MY COMPUTER WONT TURN ON AND MAKING A BEEPING NOISE
beep noise indicates that the RAM is not detected.... TURN OFF computer....remove power supply....open the cabinet and remove the RAM.... clean it using a soft non-moist cloth...plug it back.... your computer will start... still if it is not starting, then the RAM might have gone faulty, try to check with other RAM.....
Apr 28, 2010 | Compaq CV 7500 17" CRT Monitor
MY ACER INSPIRE LAPTOP MAKE BEEPING SOUND WHILE BOOTING.
when i power on my laptop the acer logo screen is displayed on screen then the computer start beeping and the laptop get struck.i replaced the ram but the same problem arise.I removed the ram but the laptop wont startup and no beeping sound.When beeping start the laptop cooling fan get stopped.
Oct 27, 2009 | Acer Computers & Internet
Computer wont start and i get a series of four
4 beeps mean your th'ers something wrong with your computer's memory. Make sure that the chips are seated firmly in their sockets If that dont help pull out the chips and reseat the chips
Hope this helps.
Sep 28, 2009 | HP Compaq dc5700 Small Form Factor -...
Emachine wont start, just beeps
This is probably a problem with your DIMM(RAM) Did u recently install an extra RAM?If yes then remove it because the beep sound is due to the mismatch of frequency of two DIMM's. If not open your computer and check if the DIMM is loose just push it in and powerup your comp..Let me know if its fixed..
Oct 08, 2007 | E-Machines eMachines Desktop PC
Dell Dimension 3000 PC Desktop Logo
1,173 people viewed this question
Ekse
Clive
Clive
Alun Cox
