If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net for parts, repair service and DIY info.
The display on my Garmin E-Trex Legend GPS is unreadable, having lines through it. It looks like a shaken up, half erased etch-a-sketch screen. Its intermittent, but becoming more frequent. My unit is about 5 years old.
Any advice?
Smitty
[email protected]
