SOURCE: new verbatim 160gb usb external
I had a simliar problem. This is how I fixed it in XP;
Remove any attached external devices except the one having the
problem.
Go to:
1. Control Panel
2. Administative Tools
3. Computer Management
4. Under Storage right click on "Disk Mangement"
5. The bad drive should show up as Disk 1 with a black bar across
the top.
6. Right click on the bar.
7.Select " change drive letter and paths " and follow the instructions.
8. If number 7 does not work, go back to the menu and select
"Format". During the FORMAT I believe you will be asked to assign
a drive letter.
9. GOOD LUCK
I acutally had this problem with two different drives. I fixed the first one using the instructions above. But the second drive didn't even show up in Disk Management. I had to return it for a new one.
SOURCE: My Verbatim 320GB portable drive will not work with my iBook G4
Called Verbatim support and they said it is a power issue. They will send you a USB Y cable to get power from both USB ports. Hope it works.
SOURCE: I hve a Verbatim USB Portable Hard Drive with
usualy it means that it has an error,try checking that the cables to the drive are connected properly if there all fine try shutting the usb drive off and turing it back on after 3 min.
you should turn your PC off also and restart it.
if that does not work you need to post more information about your PC and periferal devices.
SOURCE: verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
SOURCE: hi, my verbatim usb 250 is not working. It has a
i was goinng thorugh same thing for weeks didnt know what to do so i took it and held it with the slim side and smacked it softly on my nee and it works:D no joke:D try it not tooo hard or else itll brake:)
