SOURCE: calendar alert problems
all you need to do is when the pop up alert appears just dismiss it then if you want to delete it , go into the calendar and go to the date you are looking for and delete them.
SOURCE: Microsoft Office Outlook
Run Outlook from a command line with the /cleanprofile switch appended to the command.
To find the correct command line, right click on a shortcut for Outlook and go to Properties. Copy the information in the Target field and Paste it to the command line. If there is already a command option, remove it and add /cleanprofile after the closing quotation mark. (Add a space before /cleanprofile)
For example, go to Start: Run. . and enter something like "C:\Program Files\Microsoft Office\OFFICE11\OUTLOOK.EXE" /cleanprofile .
Then add a new profile. Be sure to check the check box for "Set as default profile". Note: You cannot see this option unless you click on the "Options >>" button.
This should fix the problem.
SOURCE: 2007 iffice Pro Hack subkeys in regedit now canit uninstall
dude ,,r u geting the activation remainder ,,i can give you a website from where you can download ms office 2007 for freee and you will not get any activation remainder ,,,
so
1.download the ms office torrent --> http://www.torrentreactor.net/search.php?words=ms+office&search=
2.then open the download torrent with azerus to start the downloadation ,,,you can download azerus from this website http://www.toggle.com/lv/group/view/kl25534/Azureus.htm
SOURCE: sent mail is no longer being saved in sent folder after upgrading
"An extension failed to initialize. Can't open file: extend.dat.
The file may not exist, you may not have permission to open it, or it
may be open in another program. Right-click the folder that contains
the file, and then click Properties to check your permissions for the
folder. You don't have appropriate permissions to perform this
operation."
Seeing that the user was an administrator it seemed more complicated
than a permission problem. What is the extend.dat file? It is a file
used to cache extensions built for outlook. Seeing that our users use
no extensions, the problem with the file could be fixed by either
deleting it or renaming it.
If hidden files and folders are not visible you will have to set
your explorer window to view those types of files. If you know how to
show hidden files skip "Viewing Hidden Files".
Viewing Hidden Files: To view folders and files
that are hidden, from my computer, click tools and then folder options.
Click the view tab at the top of the window. Scroll down to the option
Hidden files and folders. Click the option that says show hidden files
and folders. Then click OK.
The Fix: Make sure outlook is closed and not
running. If you are viewing hidden files and folders, use windows
explorer to go to documents and settings, then the folder of the user
with the error. Next click Local Settings, then Application Data, then
Microsoft, and finally click and go into the outlook folder. There is
where you will find extend.dat. Now from here rename the file from
extend.dat to extendOld. Restart outlook and send someone an email.
SOURCE: Microsoft Office Outlook % 1 is not a valid Win32 application
This issue can happen if your outlook executable (outlook.exe) is corrupt.
Follow the steps at the link below to resolve the issue.
http://support.microsoft.com/kb/258794
Please ensure that you read all precautions for preventing email loss before you start the process.
