Question about Emerson LC320EM9 32 in. LCD HDTV
Alba Flat Screen LCD 32 inch Television. Sound works OK on loudspeakers, but not on headphones. There is a "submenu" in the sound set up panel which adjusts the headphone sound only. This line is "greyed out" so I can't turn on the headphone sound. The headphones are OK, and the socket isn't broken. How can I fix this? (I'm hard of hearing and use the headphones all the time to save others from being deafened by too loud speaker sound!)
6ya staff
SOURCE:
Anonymous
  • 363 Answers
SOURCE: Headphones
This TV does not have a headphone socket, which is unusual. There are audio outputs (RCA phono) which may be used with an amplifier or tape deck to drive the headphones.
Posted on Oct 08, 2007
Anonymous
SOURCE: Hitachi L26H01U headphone socket doesnt work
User problem!! The main TV volume and the headphone volume work independently so you can have the TV volume set at zero and use the headphone volume. However I suggest getting a pair of headphones with it's own volume control.
Posted on Dec 27, 2008
Anonymous
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
milkburp
Adam Halfhill
  • 416 Answers
SOURCE: lg lcd tv 37lc2d no headphones socket - how do i
You can purchase a cable to connect to the Audio Out ports on the back of the TV. It will have 2 RCA connectors on one side that plugs into the TV and a 1/4" stereo jack on the other end that you will connect your headphones to. You could even pickup a pair of wireless headphones... they will have a volume control on them! I hope this helps.
Posted on Mar 17, 2010
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: I have a problem with
How are you getting the sound to your sound system?
HDMI? ANALOG AUDIO LINE OUT RED and WHITE RCAs? TOSLINK optical?
How does it sound with its own built-in TV speakers?
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Posted on Dec 15, 2010
Soyo 32 inch TV, no sound
First check that any muting control is not activated. This might be
a button on the remote or set itself. If you have a headphone jack, it
may have dirty contacts as plugging in a headphone usually mutes
the speaker.
If the set is mono or only one channel of a stereo set is out, then
check for bad connections to the loudspeaker. Test the loudspeaker by
disconnecting one of the wires (with the power off!) and measuring its
resistance with an ohmmeter (it should be less than 100 ohms - probably
less than 8 ohms). Or momentarily touch a 1.5 volt battery to the speaker
terminals - you should get a click or pop from the speaker.
Next, trace back from the speaker output terminals to the circuit board
and look for bad solder connections or a loose or dirty connector.
If these tests do not reveal anything, you probably need a scope (or
audio signal tracer) and schematic. Or at least the part number off of
the chip. Is the final amp a chip also or just a transistor? Have you
tested the transistor? If there is little or no buzz from the speaker,
that would indicate a problem fairly near the output. If the tuner/if were
bad, I would expect some noise/humm pickup from the low level audio stages.
Get the part number off of the chip. If it is in a socket, check the
contacts for corrosion or looseness.
Hope this helpout.....
Jul 14, 2010 | Soyo DYLT032D 32 in. LCD Television
32' Samsung LCD Tv vertical bars on screen / sound
hi,
your lcd panel micron tube has already wron out. time to replace the panel
Apr 25, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
The audio on my Sharpe LC32AD5EBK LCD TV has a vibrating sound that is getting worse. Any ideas what the problem is.
This sounds like a faulty loudspeaker , to help locate whitch one use balance control on remote from left to right, also see if fault is present on a set of headphones connected to headphone socket.
regards windyhouse
Mar 23, 2010 | Sharp LC32AD5EBK 32 in. LCD TV
I plug in headphones, but sound still comes out of TV speakers
This information was found on the Dynex website: (http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) in the frequently asked question section on page 7. If the solution below dos not work for you. You can either go to the website by copying the web address and putting it in your address bar. Once there you can use the e-mail function to talk to customer support. You can also use the Dynex customer support telephone number 1-800-305-2204 between the hours of 7am and 12 am CST. Give them the model number of your television and the problem you are having with the use of the headphones. I hope this information helps you solve your problem. How do I get headphones to work with my TV? o Connect the headphone cable to the headphone jack on the side of your TV. o The sound will be heard through both the headphones and on the TV speakers. o Press Mute to hear sound only through the headphones. o Use the volume buttons on the remote to adjust the volume level. o You must remember to press mute again to hear sound through speakers. It will not automatically come on when you unplug the headphones.
Jun 06, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
I have no sound on my 32 inch polariod tv none at all please help
What it sounds like is wiring inside to the speakers got disconnected. Does the TV have a jack for headphones or external speakers? If so, then I would connect something to see if you get sound.
If you still do not have any sound, then your audio outputs may have fried.
Jan 17, 2009 | Polaroid FLM-3225 32 in. LCD Television
My computer is connected to my westinghouse hdtv...
The computer is connected to your display port input on the TV. This transfers video signal only to your flat screen. You need to get an RCA (white and red cables for R and L, sound)to 1/8th inch cord that will plug into your headphone socket, or OUT of audio jacks on back of tv to a stereo system or receiver/amp(soundsystem)
Dec 11, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Complete black screen on samsung 46 inches
Thats Samsung for you. They are designed to last just right outside the warranty then fail. Typically the LCD panels are bad, and they are the most expensive part on that Korean unit.
Sep 07, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Mar 15, 2008 | Proview PA-32JK1A 32 in. LCD Television
No Picture or Sound from ASTAR 32 inch LCD Television
Google Allelectronics or Hosfelt Electronics for these caps
I just ordered these at a good price but ordered 35Volt instead.
Also replacing 3300uF caps too as they are bulged at top.
Hope this fixes it. Will let you know.
Nov 14, 2007 | Astar LTV-3201 32 in. LCD Television
Emerson LC320EM9 32 in. LCD HDTV Logo
161 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
