Question about Samsung LN-S4092D 40 in. LCD HDTV
My two year old son pushed a button on the remote and now our HD Samsung tv says Weak or no signal. We have tried everything including reseting it. Do you have a solution, please?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Try going to the tv itself and push the source/input button. you should go to the correct source to get your picture back. try looking for the input or source button on the remote as well. that should do the trick -gab
Posted on Oct 18, 2010
6ya staff
SOURCE:
Instructions to control samsung t v
Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
  1. TV off
Within 3 feet of TV
PAIRING and RESET buttons:
Dec 08, 2015 | Samsung Televison & Video
Why won't my samsung smart tv emote wont change chanel
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  4. Turn on TV
  1. TV off
Within 3 feet of TV
Please rate if Helpful.
Good Luck !!
May 25, 2014 | Samsung TV Remote Control
My samsung 3D led multisystem smart TV remote control does not work anymore
  1. TV off
  4. Turn on TV
Good Luck !!
  1. TV off
Within 3 feet of TV
PAIRING
and RESET buttons:
Apr 15, 2014 | Samsung TV Remote Control
Remote will not work
  1. TV off
  4. Turn on TV
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
Mar 05, 2014 | Samsung TV Remote Control
Samsung tv has never responded to the remote control
  1. TV off
  4. Turn on TV
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
Feb 15, 2014 | Samsung TV Remote Control
Samsung, cablevision and tivo - weak or no signal message
With the TV remote you must select which signal input that you want to watch. You can have a TV cable, an HDMI plug, AV, and component, all connected at once and watch the one that you want to. After you select which ONE that you wish to see displayed on the screen, you will have to use the remote for that device
Feb 03, 2018 | Televison & Video
Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Jan 01, 2010 | Samsung LN32A330 32 in. LCD TV
No signal or weak signal
Sorry I see the model,
hold the Menu button on the TV (not on the remote) down for three seconds.
Note: Shop Mode is activated in the same manner: Pressing and holding the Menu button on your TV for three seconds. To avoid accidentally setting your TV to Shop Mode, avoid pressing and holding the Menu button on the TV for three seconds or more.
Sep 21, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Weak or no signal message
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Jun 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Ds3224
push reset on remote twice quickly
Jan 05, 2008 | Sanyo DS32224 TV
Samsung LN-S4092D 40 in. LCD HDTV Logo
309 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
