Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
Posted on Oct 18, 2010
Sony Bravia LCD No picture, no sound I can pull up direct tv guide and all menu's but no pic or sound.
Anonymous
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Oct 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
15491
Points
46
Have you check other sources connected to the tv? if you can pull up directv box menu then tv is good. issue with directv box. try to unplug directv box for 1 min
Connected to cable box sound no picture reboot left tv on 3 hrs. fine. turned off. 2 hours later turned on now no pic just sound. When the tv is cold no pic. when warm pic. ???
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
Sony bravia KDL 40S4100 No picture
If you wish to get some details; check the site linked here. Pull up older posts.
Troubleshooting procedure for No-Picture is given in detail.
We have sound but no picture
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 467,264 views. 2:30. LCD & LED TV Repair - No Image ...
How to fix sony bravia has black screen - Digital TV - Streaming ...
www.tomsguide.com/forum/56867-4-sony-bravia-black-screen
Aug 19, 2014 - 12 posts - ‎11 authors
Hello, My Sony Bravia TV screen has gone all black. The green on/off light comes on,but no picture appears. The model ... Your solution solved the non picture for live tvbut still no picture (just sound) fir OnDemand. Score. 0. No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
Tv problems picture ok but no sound - HDTV
Sep 8, 2011
More results from www.tomsguide.com
1helpful
Get a picture but no sound
Unplug,replug the tv about an hour later.Let the tv reset it self.Go to the menu,go to Audio setting,go down reset.The tv audio will work again.Not,than ur Tuner board is dead.Must be repalced.
Bravia 46 works fine from a dvd, but on tv, the picture keeps breaking up with coloured patches obliterating parts of the picture and the sound misses bits. The old CRT tv works fine when plugged in to the...
You may want to try a signal booster,or a different arial.Not sure if your old CRT or arial was digital ,but you should have a tools button on your remote or a diagnotic option in your menu that will show signal strenght.I have a Terk HDTVo.It is a small bomarang shaped antenna that pics up stations 50 miles north (direction it is pointing)and the only issue is when storms roll thru.I have added a motorola 484095-001-00 signal booster and that has solved most of the issues with the farthest stations plus added a few more from different directions.You could also add a antenna and if your original arial is run with coax just use a diplexer to combine the signals.Well hope this helps and good luck.
Their is sound but nothing is visible
U can ecess the menu go to word tv,see if can get out to tv.Repaced the LCD inverter board,it may be dead.
2answers
I have a sony bravia xbr 32 inch and the picture is only on half the screen
It is possible that Twin Picture function is enabled, turn it off with remote/ menu options.
If this is not the case then T-Con board sounds bad and needs to be tested/ replaced.
Qualified tv tech will test and replace it.
Thanks.
FullHD KDL46XBR2 Bravia: No pic, no sound
call a tv place and order a lamp for it if your not old to lift it
1helpful
2answers
It was working fine then no picture dark sceen sound work fine
More information is required. Your backlight is lit (screen not dark) but I need to know what you have connected to the TV (your sources) and how they are connected. Does the menu/OSD (on screen display) work?
1helpful
2answers
Sony Bravia with Phillps dvd player
The DVD player may have multiple output formats that can be displayed. Sounds like you have the composite output selected when you have the component output selected on the DVD player. Check the menu options on the DVD player and confirm they match the way you have the player connected
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
