I have a ZR100 that did the same nearly the same thing - but it was only beeping twice. I followed the advice another thread suggested - I banged it twice on the opposite side from the door but it didn't fix it. Then I banged it twice on the side with the tape door.... and now all is well!
I couldn't believe that "fixed" it. Like banging the ol' tube color TV on the side to fix the picture. Maybe it is short lived, but if it holds for the rest of this year until the camcorder Christmas sales begin, I'll be happy!
If you can't return the camera for service, my advice would be to close the battery compartment with tape. Not pretty but better than buying a new camera, I've done it a few times on old cameras and apart from cosmetics, works fine. Just make sure to use enough tape so the batteries won't fly out when using it.
there is a risk of hardware damage.make sure you dont force the tape into the cassette compartment to avoid damage to the unit or tape.here's what you can do.
1.remove the tape from the compartment.
2.ensure proper type and size of tape is used.
3.ensure no packaging material or foreign material inside the compartment.
4.if attempting to record, make sure cassette tape rec/save switch is set to rec position.
5.reinsert the tape, make sure it's properly inserted.
6.if still won't close or tape ejected again,remove tape.
7.reinsert a diff tape.
8.attempt to close compartment.
9.if issue unresolved, press the tiny reset button while cam is powered on (located in the panel where the lcd screen goes to,just below all the other buttons). you may also do a power reset procedure: remove batt, remove ac adaptor,set power switch to vcr, leave the cam without power for at least a minute, switch power back to off, reinsert ac adaptor/batt and turn cam on, attempt to close tape compartment.
if issue persists, service would be needed. hope this helps.thanks:)
I just posted that I had the same problem with the Elura 100 not taking the cassette, although the compartment will close without a cassette. And I did have the problem with the left wheel rewinding, then the beep occurs.
I was tinkering a bit. I decided to take some video on the SD card, and I let it record for a moment. After that, I went back to trying to get the cassette compartment closed, and it worked! Almost like the camera needed reset.
We'll see if it stays corrected!
Prior to that, I have tried using a can of air, loading a new cassette, etc. And I DEFINITELY did NOT have any condensation!
Hope that works for ya!
Several things could be happening...the tape is backwards, upside down, inverted or just wrong type since it closes without it. Next check to see on the inside if something is jamming the tape. While it closes without a tape there could be something that jams when a tape is inserted.
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
I had the same Problem. My Solution was i open the camera, then i take the batery away. I put the tape into and close the camera, then i put the battery into and the camera close with the tape
My ZR100 also does not close when I put a tape in, but it does close when there is no tape in.
I have the same problem. Hopefully someone can provide a solution.
Problem fixed for now by other comments saying to gently bang the side of camcorder.
