Dell OptiPlex GX620 PC Desktop Logo
Posted on Oct 17, 2010
Just looking for the motherboard manual and cd for a dell optiplex gx620. I'm learning about my computer.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Oct 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1088
Points
14
You can download the manuals for your OptiPlex GX620 PC directly from the Dell website here:
http://support.dell.com/support/edocs/systems/opgx620/en/index.htm
Power light orange
Open the box (unplugged) and take the memory out. Plug it back it, if you turn it on and there are no beeps, the motherboard has gone bad. Only fix is to replace the motherboard, or replace the whole computer. If it does beep, the memory is bad; replace the RAM (memory) While you have the computer open look at the little can like objects close to the back opening of the computer. If they have brown goo on top of them, or around them, or if the tops of some of them are dome shape, the motherboard is shot. This was a common problem with some of the OptiPlex units.
Reset bios password
Rajesh,
You can click the link below to download the online user manual. There is a section within the manual titled clearing forgotten passwords by using the jumpers on the motherboard.
Dell Optiplex GX620 Online Users Manual
http://dell.to/1dPbux6
Thank You,
Dell-Jesse L
Dell Social Media and Communities
My dell GX620 desktop does not power when ever I plug in the network (RJ 45) cable. Also if the system has boots to desktop, and I plug in the network cable it automatically goes off.
1) Does it have a separate Ethernet Card, or is it integrated?
(Part of the motherboard)
Reasoning?
The Dell Optiplex GX620 comes with Integrated networking.
The chipset is a Broadcom 572.
It's part of the motherboard, and you plug the Ethernet Cable into the back of the computer.
However, you could have a separate Ethernet Card, plugged into the white PCI expansion slot on the motherboard.
http://www.ebay.com/itm/Dell-Optiplex-GX620-SFF-Motherboard-F8101-KH290-PY423-20-Available-/370743464509?pt=Motherboards&hash=item565208523d
A) If you are using a separate Ethernet Card, replace it.
B) If you are using the Intergrated networking of the motherboard, (Plug Ethernet cable into back of computer), use an Ethernet Card instead.
White PCI slot.
You have a short circuit when you plug the Ethernet Cable into the motherboard. Don't use the motherboard networking, use an Ethernet Card.
2) Plugging an Ethernet Cable into a computer that is on, = No.
It is not a Plug N' Play item.
(Not stating this is what you are doing.
Just posting in case you are. Burns out the Ethernet chipset on the motherboard)
For additional questions please post in a Comment.
Regards,
joecoolvette
Dell motherboard beeps 5 times
well its seems to be win the lottery,or hammer,or change the CPU
Optiplex gx620 starts up but won't go into windows just comes up to start in safe mode but if I select in safe mode it comes back to safe mode. Looked in setup and see an alert "out of range"...
These issues are usually caused by the bad capacitors on the motherboard as Computerscot stated. Here is a repair guide that shows how to check your board for the bad capacitors and what to do if you find them.
http://www.ccl-la.com/blog/index.php/dell-optiplex-gx620-motherboard-repair/
I hope this helps, if so please rate my solution.
BuddyMc
Intergrated sound max not working
may be your computer have no proper sound drive so u must install your sound driver first after we can check the hardware error of your motherboard.. you can download driver from here http://www.getpcmemory.com/drivers/download-dell-optiplex-gx620-desktop-pc-windows-xp-vista-drivers/
2helpful
Dell Optiplex GX620 Desktop PC's south bridge IC heats up abnormally...
Check the capacitors on the motherboard, Dell had a BIG problem with faulty capacitors on the GX270, GX520, GX620, GX745 and GX755 units. The parts would cause the unit to either not boot at all or lockup booting or running programs. I would bet you have some that are just beginning to fail and the motherboard power is not stable which would mean the chips are not getting enough power. Here is a link to an article about the issue and what to look for on your board.
I hope this helps you out, if so please rate my solution.
BuddyMc
I have a Dell Desktop GX620 with 1 gb Ram, 250 GB HDD and Pentium D Processor. Whenever I use the System, it will start and then after a proper shut down. I will start the system again, the three beep...
Here is a link to a manual for this computer.
http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1166448
Look where it states Diagnostics lights and see if the light patterns in the back panel lights match any on the list. It might help you on pin pointing your issue. If it is a memory issue and you have already replaced it then it is the motherboard.
found this link on ebay.com
http://shop.ebay.com/?_nkw=Dell+Optiplex+Gx260+motherboard&_sacat=See-All-Categories&_fromfsb=&_trksid=m270.l1313&_odkw=Dell+Optiplex+Gx260&_osacat=92924
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
