it's an 18 " poulan bar and chain...just a standard bar and chain for poulan...most of the aftermarket brands have a cross reference that will give you an idea on which to use
If the chain is off the bar slide then you have to loosen the set screw on the bar on the side where it goes into the main body, may be undser a cover.....
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
I have a Poulan Pro 295 20". When I bought it I also bought a 16"bar and chain and have been using those since. They make the saw much easier to handle and are a better match to the available power.
The key dimension is from the bar's mounting hole to its end. At the store look at the normal replacement bar for your 18" saw, and pick out a 16" or even 14" bar with the same dimensions there. This can be easily seen by laying one bar over the other.
