SOURCE: Fitting replacement ink cartridge
this may help you to change the ink http://esupport.epson-europe.com/ViewArticle.aspx?lng=en-GB&kbid=311830&data=wsMoc1iChVGcisk9ncQeIGFU002FHBhpsVxk
good luck
riz.
SOURCE: REPLACED TWO 68 CARTRIDGES IN CX9400 EPSON
Generic carts are sometimes not recognized. Epson's chips are the cause. I solved this problem for a small investment. I purchased a CISS system for about $75.00 [ink included], that's the cost of OEM carts that do not last very long. The CX9400Fax is an Ink Hog, which is why the printer is so cheap. If you want a CISS go to http://www.inkproducts.com/ink-store/ They are great if you need help and will call you back in less than an hour. Get the Waste Ink Kit when ordering the CISS.
SOURCE: Replaced Epson printer cartridges with Tesco ones
Took cartridges back to Tesco Customer Service desk - they didn't quibble even though I didn't have a receipt (Tesco is written all over the packaging and cartridges!) they offered me money back or a replacement. The lady behind the counter advised that her son tells her that there are just bad batches of cartridges and swapping them often sorts the problem. I took another pack and put them in the printer and Hey Presto - printer works just fine and dandy.
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through
the motions of the printing process, kind of stands still with indicator lights
just blinking away. This could be as a result of either of these scenarios.
i.
Ink cartridge
has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink
is finished. You must replace cartridge one at a time). If lights stop blinking
it confirms that your cartridge has become incompatible or developed
incompatibility. Also if your printer is the type that can work with only one
cartridge, remove one after the other (closing back the lid/cover) to determine
which in the set (black or color) has become incompatible. At the instance the
incompatible one is removed and you close the lid, the blinking will stop (for
printers that can print with one ink cartridge only). Just replace the
incompatible one and start printing again. In most cases the issue is always
with one cartridge. But if both are affected, you have to replace both. Because
of this type of problem, always keep used cartridges somewhere safe; they come
in handy for this type of troubleshooting.
ii.
The Cartridge
electronic panel is dirty
The electronic panel on the cartridge that makes contact with the
cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the
cartridge with copper “dots”.
The
Solution is to try to clean this panel with a piece of folded tissue paper
soaked in a bit of methylated spirit. Also try to clean the area in the
cartridge carrier/holder that makes contact with the cartridge’s electronic
panel (Usually this is more difficult). If you cannot reach it with your
fingers, use a stick or something with tissue wrapped around it. Allow to dry
well and return the cartridges, close the cover. The blinking should stop if
the electronic panel is the issue. Once the blinking stops the printer will
print.
SOURCE: Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
