Sounds like it is low on coolant. Add coolant, drive the car, let it cool down, and then repeat the problem until the coolant level stays constant in the coolant tank. If it doesn't stay constant after a few tries, there may be a coolant leak inside the engine (blown head gasket or intake gaskets).
Try letting it warm up for at least ten minutes. Then add waffle batter and leave closed for about five minutes and check the waffle. If it is way over done try three minutes other wise adjust your time in thirty second increments. You should have great waffles in three or less tries.
First and formost make sure air filter is clean.Then start bike and warm up engine.with engine warm adjust idle screw(the big screw with spring around it)Turn clockwise to increase and counterclock wise to decrease.with bike idling properly the low speed air adjustment screw (small screw located just above fuel bowl on side of carb)Adjust in small increments 1/16 turns at a time till bike has smooth throttle responce.This screw contols air flow during idle and up to 1/4 throttle.From 1/4 throttle and up the needle setting on plunger inside of carb takes care of 1/4 and up.You usally dont have to mess with needle unless you do upgrades to get more power out of bike.But over time the low speed settings can change due to wear on idle needle and air needle.So thats why you have to make adjustments.If bike still dosent respond or idle correctly I would purchase carb rebuild kit and your problem will be solved.
If you have never defrosted it before, leave it off for a lot lot longer, doors open in a warm area. Is the fan working when you close the door ?(or hold the door switch in), if not, there could be a problem with the condenser fan), otherwise 90% of the time, they are frosted up internally, and because of good insulation, need time to "warm up" inside, in order to defrost
You can try the suggestion on the site I posted below. This site addresses a specific problem that tends to be fairly common in some Sony sets. Only try this if your sure that the problem your having is the same problem described in the site. Look at the picture of the screen on the site and see if that looks like your screen. The set on the site is red but it could be Green or Blue also. If you set won't stay on, you may have to turn the appropriate knob down slightly in order to get the set to stay on. Although he mentions this will fix a convergence problem, the fix described has nothing to do with convergence. The symptoms you are describing do not sound like a convergence issue. I am however a little concerned about the smell. Another thing is, after the set shuts off the Led will blink a code. For example it may flash 8 times then pause and repeat. You can Google this to find out more info on the problem. Many things can go wrong with TV's, I recommend you do as much research as you can to narrow it down. Good luck, here is the site.
I just fixed our rice cooker with the same issue - turns on and warms, but won't stay in 'cook' when the lever is pushed down. My solution was: the pot that goes inside the rice cooker was dented on the bottom and was not pressing down on the mechanism at the bottom of the cooker. Once I flattened the bottom of the pot, it works!
Sorry Bud you cant. An original remotes available at http://www.remotes.com or 1800-remotes for about $61.00 + shipping. Without seeing a picture Im not even sure if thst will help ya man. If you wanna try to see if an alighnment will help then get the remote. I would advise you against doing any sort of technical alighnments as this set has high voltage around inside even afterv its been disconnected for a while. Good Luck
