We have the soap in, door completely shut, picked the normal cycle and all that happens is that the normal cycle light continues to blink when we try to push the start button. The door won't lock and start the washer. We have unplugged the washer and plugged it back in hoping to reset it, but it did not work. Can you help?
Washer Not Filling:
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
Our HE3 is doing the same thing. I checked the door latch and everything looks like it's still intact. The start button doesn't respond at all, though.
I have the same problem and the door latch looks fine.
washer won't start the door is close and the lights come on but when you press the start button nothing happens and I have tried unplugging it and plugging it back up
We are having the same problem! I checked the latch and it was not broken and is stil present; however, in messing with it, it appears that I have locked the latch and can't get it to release and now I can't shut the door.
Having the sane problem. Door latch is working because diagnostic test program works fine. Could it be the control board??
The washer starts normally but continues to try to adjust the load and reports "sensing" for an additional 45 minutes or more on every cycle.
