I bought a replacement AC/DC adapter for my Portable DVD Player, but the tip I chose, while having the right inner and outer diameters (Inner:1/7 mm\ 1/16")(Outer: 4.0 mm\ 5/32"), wasn't long enough (the one I bought was an 8 mm long metal shaft, the one I was replacing had a 10 mm long metal shaft]. Is there any place where I can buy a longer DC plug? I need positive polarity.
Try taking the washer to a local hardware store, They should be able to find a replacement. (Normally the smaller stores have a better selection of the single washers than the big box stores) Also there's a company called MSC that has just about every washer imaginable, however you'll pay more for shipping than what its worth.
Take it to Radio Shack...they
have a full line of replacement AC adapters. You may find one that
matches or a multi-selectable model. You may have to order. My PVS12701 adapter has: Input 100-120V 50 60 Hz 0.40A Output 9.0V DC 1500 mA tip has + center, - outer
You need to input the correct voltage, amperage, the correct polarity, the correct outer diameter of the plug, the correct inner diameter of the plug. Don't worry about the input voltage, 117, 120, and 125 are all the same.
