I am trying to get my sylvania tv to work with the universal rca remote. the original remote went kapooey or lost codes, just won't work. HELP
Trata con esto.
Presiona el boton Code search y mantanlo asi hasta que el led se quede encendido suelta y presiona el boton TV despues vas a presionar y soltar el boton Power hasta que el televisor se apague despues presionas el boton enter y el codigo queda almacenado.
El Tv tiene que encenderse primero manualmente.
006,007,010,011,013,016,027,
033,035,043,049,066,087,089
Programming method
[1] Press the button of the device you want to
control (for example TV).
[2] If the device turns on, press another button,
to confirm (for example CHANNEL UP)
[3] If the device you selected (TV) responds,
you will not need to program the remote.
If the device you selected (TV) does
not respond, you will need to program
the remote
There are very rare RCA remotes, with Sylvania TV can be programmed. Just try the above codes with your present RCA remote control. If it does not help, buy the above model RCA universal remote. You will get code list and all other related documents, how to programme it or so, with the device you do purchase. OK.
need code for att remote
I have the same problem. None of the codes supplied with the remote work on the Sylvania TV.
I tried the RCA and Phillips remotes, neither one worked. So I purchased the original Sylvania remote and the TV still won't work. You can turn it on manually though.
does work
