SOURCE: My Dell inspiron 518 will
Green LED on PS means it's getting AC power. Orange light on motherboard means it's receiving power from PS but it may not be the correct voltage. The power supply isreceiving power from the source but is unable to properly distribute it to thecomponents. This can be caused by a defective power supply or a defectivemotherboard. Just to make sure that nothing else is causing the problem, removeany PCI cards like modem, video card, sound card, etc... Remove the memorymodules and disconnect cables to CD/DVD drives. Look at the USB ports to see ifany are damaged.
SOURCE: will not turn on when
Green LED on back of power supply indicates it's getting power. That does not mean that it's distributing the power voltages to the computer. You could have a bad power supply or a bad motherboard. Just to make surethat nothing else is causing the problem, remove any PCI cards like modem,video card, sound card, etc... Remove the memory modules and disconnect cablesto CD/DVD drives. Look at the USB ports to see if any are damaged.
