Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
My Belkin N1 and my xbox 360
Ok. this is a little complicated so I'll try and explain as clearly as possible. I bought a N1 wireless router from belkin and it works great I have but one small problem. I have an xbox360 hardwired to the router and two computers connected wirelessly. I'm trying to access the photos, music and videos on my computers using microsoft media center on my xbox. Both my computers acknowledge the existence of my xbox but my xbox can't access the computers... why! with my old router this worked fine, and when I hardwire the computer it works fine.
Help!
  • JaimeEs May 11, 2010
    What version of the router do you have? Have tried loading the lastest firmware for that version?
I just got it and yes latest firmware as of end of mai has been downloaded
Posted on Jun 13, 2008
6ya staff
SOURCE:
Hi, I'm using a Belkin N1 wireless router. I mostly have a stable internet connection, but once in a while the "wireless" icon start blinking orange. What is this? My internet some times get...
if the wireless light is lit up in red it says "someone is trying to connect to your network using wrong password"
Sometimes if any of your devices are not compatible with the security enabled in the router then the light will lit up in red. click here to know more about security types of belkin router
routers has to be turned off atleast 2 hours per day for it to work properly... so better turn off the router when not in use, this will clear the routing table of your router and will make the router to work as a fresh router everyday, so you wont face any speed problems.
May 03, 2011 | Belkin N1 Wireless-N Wireless Router
My internet is greatly reduced with Belkin N1 vision wireless (before the hook-up it was 15mbps now only 5mbps), I have tested by hooking directly from the modem to the computer and got 15mbps. Before N1,...
When you only get 5 mbps are you connecting to the new router wirelessly or via the ethernet cable? If it is wirelessly then try connecting with an ethernet cable and see if you still get 5 mbps. If so then try resetting the router (the procedures for this will be explained in the manual) and re-test. Wireless connections can slow down due to obstacles such as thick walls or other obstacles of that type. If all else fails return the unit and try another.
Mar 08, 2011 | Belkin N1 Vision Wireless Router
Keep changing the language
I suggest you contact Belkin customer service and explain your problem. They will either walk you through the steps required to fix it, or (assuming your router is new and under warranty) replace your router with one that works properly.
Feb 16, 2010 | Belkin N1 Vision Router
Belkin N1 Wireless router wont fully connect to laptop
if you connect your xbox and it works than it is not your isp
go to your network setup and try it with fix ip and DNS to you vista laptop wirless card /fixed card ip setup
goodl luck get back if this does not work with more info on your network setup
Jun 12, 2009 | Belkin (F5D8231-4) Wireless Router...
Email problems with Belkin N1 wireless router
Disable your Firewall/NAT service or open ports 25, 110 and 141
Dec 12, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin w/range extenter question
you can use as many as you want, since they just find a signal and amplify it. using more than one shouldnt cause any problems
Nov 07, 2008 | Belkin (F5D8231-4) Wireless Router...
FixYa's Maanita was no help whatsoever, and worse, a complete waste of time.  I called Belkin who's tech guided me to the problem in ten minutes, whereas I wasted an hour and a half with FixYa.
Jul 04, 2008 | Belkin (F5D5231-4) Router
Belkin N1 Wireless not STAYING connected
change channels to 1-6-or 11. Make sure you change all of them.
Jan 07, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
165 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
