its is simple on the desktop click right button of the mouse and select new and then click on it
you can create your own folder.pls visit the following site
HP LaserJet MFP and All-in-One Products - HP Universal Print Driver: Bin ... and LaserJet AiO/product Products - Solve Common Macintosh problems 25 Mar 2011 ... h20000.www2.hp.com/.../SupportTaskIndex.jsp?... - Cached - SimilarHP LaserJet M4345 Multifunction Printer series - Manuals - HP ...HP LaserJet M4345 MFP - (multiple language) Getting Started Guide North ... h20000.www2.hp.com/.../SupportTaskIndex.jsp?... - Cached - Similar
Hi, Remove all the papers from out put bin & check if not solved remove both side and top covers absorve right side of the out put bin flag sensor clean it with high pressure air or clean with dry cloth gently. Best of luck...Vinay
A flag in the output bin is activated. This flag moves up while the paper is making its way out of the printer and drops as soon as the paper drops into the output bin. When the tray is full the flag will stay activated or in the "up" position instead of down. Telling you to empty the bin.
You can see this flag in the center on the delivery assembly(where paper exits). The flag should be free to move up and down. Gently see if the flag will come loose. This flag is delicate so if you push or pull to hard you will break it.
The only other way to lease this flag would be to remove the top cover and reposition it. Of course this would be a little more involved and would require a new set of instructions.
