Computers & Internet Logo
Posted on Oct 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fans are not working - Targus Computers & Internet
Anonymous
Level 3:
  • Master 656 Answers
  • Posted on Oct 14, 2010
Anonymous
Master
Level 3:
Answers
656
Questions
Helped
147830
Points
1598
First check ur smps wether working by shorting green and black if not change ur smps to new one if working and still fan not working chenge ur fan and check working still not working the is fet near the processor fan change it or contact chiplevel service personsal
Bionaire Dual Fan, one fan is not working?
Take it apart and swap the fans over.
If the none working fan still doesn't work, you need a new fan motor.
If the none working fan does work, you have a wiring issue.
https://www.google.com/search?q=Bionair+Dual+Fan
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Dodge Stratus R/T fan doesn't come on while car is running and car is getting hot.
FAN NOT WORKING
It can be issue with faulty motor or its faulty fan control relay.
Bother are to be inspected.
Test volt at fan relay and fan motor.
For more help, I suggest you to go through the troubleshooting links mentioned below:-----
Click the link below: ------
How to replace Cooling Fan on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cooling-fan-on-acura-car.html
OBD Code P1490 low speed fan relay ckt open-short
http://schematicsdiagram.blogspot.com/2012/11/obd-code-p1490-low-speed-fan-relay-ckt.html
Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works?
http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
Hyundai Sonata cooling fan not working
http://schematicsdiagram.blogspot.in/2012/02/hyundai-sonata-cooling-fan-not-working.html
Fuel pump relay and cooling fan relay troubleshooting on 1997 ford thunderbird?
http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
Fan belt routing diagram for 2004 Volkswagen Jetta?
http://carbeltrouting.blogspot.com/2011/12/fan-belt-routing-diagram-for-2004.html
Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
A/C, heater, defroster fan, not working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Blower fan not running on Isuzu trooper?
http://technoanswers.blogspot.in/2012/02/blower-fan-not-running-on-isuzu-trooper.html
How to replace blower motor fan assembly on 2000 GMC Yukon?
http://repairhelpcenter.blogspot.com/2012/01/how-to-replace-blower-motor-fan.html
Heater AC or defroster fan not working on KIA?
http://technoanswers.blogspot.in/2012/02/heater-ac-or-defroster-fan-not-working.html
These will help.
Thanks.
7helpful
3answers
Fan won't work
Bother are to be inspected.Test volt at fan relay and fan motor.-------------
For more help,i suggest you to go through the troubleshooting links mentioned below:-----Click the link below:------
------------These will help.Thanks.
2004 grand marquis fan quit working..replaced fan but still wont work
is this the blower motor fan for you heating and A/C or the cooling fan cooling fans have a relay blower fans are fused but controlled from switches inside as well as fuses
Ceiling fan won't run but the light does work. Fan has worked in the past but now just the light works. Why would the fan not work? This is a Hampton Bay Northport III ceiling fan ( product of Home Depot)
mcdevito75 here, You say fan worked in the past, That tells me the fan has not run in over 1 month if so, try this. First, the fan motor is a sealed unit, without running the fan in over 1 month it may be a little stiuck, put the fan lights on, and pull the fan chain just once and turn the fan blades themselves just a little to get thm started. also verify fan switch itself is good, Chain switch should have the familiar click click to it. If not the fan swich could be bad.
Fan works but light does not. bulbs are good.
mcdevito75 here, The lights should work from the wall light switch and the fan from the pull chain on the fan itself. The fan and the lights come off the same wall circuit so if the fan works, so should the lights, however in the fan assembly itself 1 wire was for the lights and 1 wire was for the fan. You'll have to pull the fuse to that fan, and remove the cover to the fans wireing at the ceiling., Now you can see the fans wireing, I'll bet the wire to the lights has fallen offf due to the vibration of the fan. Hook up the loose wire and the lights should work. If you can"t do the work, look for a handy man in your building / Area.
2helpful
One of my fan is not working 1999 Honda Accord
Which fan is not working, A/C or Radiator? Check fuses, if good disconnect fan plug, direct wires from battery to fan to check fan, if fan does not work change. If fan works check water temp sensor for radiator. A/C fan only comes on when A/C is switch on. Like wise radiator fan only comes on when water reaches a certain temperature.
LIGHT AND FAN ARE NOT WORKING. HAMPTON BAY LIGHT IS NOT WORKING
Could be a loose wire up inside the fan. I would be very careful in its use. Might I suggest getting an electrician in to resolve this issue. You do not want to battle a fire over a fan light issue.
1helpful
Intermittent operation of interior fan - isuzu kb/trooper
fan speed resistor block blown if fan works only on full speed (because power goes directly to fan on full speed, not through resistor)
if fan doesnt work on full speed check for power at fan on full speed with test light if power there fan faulty
no power check switch bank assembly
Top Targus Computers & Internet Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
