Cars & Trucks Logo
Posted on Oct 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I would like to get a belt diagram for a 1988 pontiac firebird trans am
  • Anonymous Mar 29, 2014
    the schematic diagram of the door and window assembly would be what I need
PHIL HINES
Level 2:
  • Expert 266 Answers
  • Posted on Oct 14, 2010
PHIL HINES
Expert
Level 2:
Answers
266
Questions
Helped
74558
Points
867
GO TO ACCESSDAYCO.COM AND YOU CAN SEE IT THERE
Duane Wong
Level 3:
  • Pontiac Master 6,826 Answers
Duane Wong
Pontiac Master
Level 3:
Answers
6826
Questions
6
Helped
2861546
Points
20234
ADJUSTING V-Belts Fig. 1: A gauge is recommended, but the belt deflection may be checked using light thumb pressure i would like to get - 85341063.gif
Fig. 2: Loosening alternator pivot/adjustment bolt in order to tighten the belt 85341094.jpg Fig. 3: Apply tension to the belt being careful not to damage the case. While holding accessory in this position, tighten the pivot bolt. Fig. 4: Using a 1?2 in. ratchet, apply tension to the air conditioning belt while tighteni would like to get - 85341096.jpgt bolt 85341096.jpg Belts are normally adjusted by loosening the bolts of the accessory being driven and moving that accessory on its pivot points until the proper tension is applied to the belt. The accessory is held in this position while the bolts are tightened. To determine proper belt tension, you can purchase a belt tension gauge or simply use the deflection method. To determine deflection, press inward on the belt at the mid-point of its longest straight run. The belt should deflect (move inward) 3?8 - 1?2 in. (10-13mm). A general rule for alternator belt tension is that the pulley should not be capable of being turned with hand pressure. Serpentine Belt On most newer vehicles, a single belt is used to drive all of the engine accessories formerly driven by multiple V-belts. The single belt is referred to as a serpentine belt. All the belt driven accessories are rigidly mounted with belt tension maintained by a spring loaded tensioner. Because of the belt tensioner, no adjustment is necessary. REMOVAL & INSTALLATION V-Belt Fig. 1: Loosen the component mounting and adjusting bolts slightly 85341064.gif
Fig. 2: Remove the belt by pushing the component toward the engine 85341065.gif
Fig. 3: Remove the drivi would like to get - 85341066.gifrel='nofollow' href="http://arrc.epnet.com/autoapp/9100/chiltonimages/8534/85341066L.gif">85341066.gif
Fig. 4: To tighten the belt, pull the component away from the engine and tighten the mouni would like to get - 85341067.gifo specifications 85341067.gif
To remove a V-style drive belt, simply loosen the accessory being driven and move it on its pivot point to free the belt. Then, remove the belt. It is important to note that on engines with many driven accessories, several or all of the belts may have to be removed to get at the one to be replaced. Serpentine Belt i would like to get - 85341068.gif Serpentine belt tensioner - V6 engine 85341069.gif
A belt tensioner is used on these models, to maintain proper belt tension. To relieve belt tension, rotate the belt tensioner (using a 15mm socket) to relieve pressure on the belt. With tension relieved, the belt may then be removed from the engine. It is important to note the belt location at each pulley, to assure correct installation, and proper operation of the engine cooling system. A diagram may be helpful in denoting belt positioning. NOTE: Take care not to bend the tensioner when applying i would like to get - prev.gifDamage to the tensioner will occur. Maximum torque to load belt should not exceed 30 ft. lbs. (41 Nm). i would like to get - next.giff="http://arrc.epnet.com/autoapp/9100/9100CH01_Belts.htm">prev.gif next.gif
1 Related Answer
Anonymous
  • 484 Answers
  • Posted on Oct 26, 2009
SOURCE: Diagram for Routing Serpentine Belt firebird
V8:
http://www.mvreader.com/multiview/dayco/zoom.php?zoom_item=C0000U&l=n&catalog=auto&category=2
V6:
http://www.mvreader.com/multiview/dayco/zoom.php?zoom_item=C0001D&l=n&catalog=auto&category=2
1989 Pontiac Firebird has no power, and will not start.
Clean battery connections and lightly coat with Vaseline. Check the earth lead on the negative connections has a nice clean bond to the bodywork.
There doesn't appear to be a main fuse, but check on the positive battery lead.
https://knigaproavto.ru/shemy/en/pontiac/firebird/850-1988-1992-chevrolet-camaro-and-pontiac-firebird-fuse-box-diagram.html
Adjust the clutch linkage on a pontiac 2002 trans am 6 speed
How to adjust clutch??? 95 bird. - Fourth Generation Pontiac ...
www.firebirdnation.com/forums/.../65178-how-to-adjust-clutch-95-bird/
Dec 5, 2008 - posted in Fourth Generation Pontiac Firebird (1993 - 2002): I have ...Year: 2000; Make: Pontiac; Model: TRANS AM; Engine: 5.7L LS1; Transmission: MANUAL 6 SPEED T-56 ... Have you looked at your clutch master cylinder. Throttle is sticking after acceleration - Fourth Generation ...
Oct 7, 2011
1 Problem / Few questions - Fourth Generation Pontiac Firebird ...
Mar 26, 2010
Firebird Technical Service Bulletins - Fourth Generation Pontiac ...
Jul 5, 2006
TECH ARTICLE MASTER INDEX Look Here - Firebird Nation
Aug 18, 2004
More results from www.firebirdnation.com
How to Install Clutch 98-02 LS1 F-Body Part 1 of 2 - YouTube
? 12:31
www.youtube.com/watch?v=4BCHu2BwBMs
Apr 12, 2013 - Uploaded by MapleBoarder78
Part one of installing a new clutch on my 2000 Trans Am. Part 2 will include installation ... How to Master Cylinder Install and Drill Mod (LS1 F-Body) - Duration: ... 6:28. Removal and Servicing ofClutch Master Cylinder to Slave Cylinder ... LS1 98-02 Chevy Camaro Z28 SS Pontiac Firebird Trans Am F-Body ...
I need to download a1996 firebird manual
Yes. Go to the Pontiac Firebird/Trans Am owners forum and join it. You will be able to download manuals and get answers and tips about working on your car.
Pontiac Firebird Trans Am Forum Pontiac Forums
I have a 1988 pontiac fire bird and i took it a part to rebuild it and have it all back together and lost the belt route a possibly a pulley but can't figure out what one is missin if there is one missing...
It sounds like you are missing the idler pully. I need to know what size motor you have to get you the diagram. If this car is a v belt style you manually set tension. If this is serpentine belt style sound like your missing the tensioner too.
1988 firebird trans am wont shut off when the igniton its turned off. it wont shut off in park, my wife put it in netural and still didnt shut off. neighbor came and put it in netural and took the key out...
You are having what is called dieseling, this is caused by the carb not shutting off the fuel supply when you turn the car off. They have kits at kragen to repair this issue.
2answers
1988 Pontiac Firebird - vacuum leak
go to autozone.com, become a member(completely free and safe) and then you can access their repair guide section which contains a vacuum diagram for your 'bird....you'll use that site a lot.....need to get yourself a haynes manual for your car-.....thanks for the question...ps- also check out a forum just for firebirds....hope this helps
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
