Question about Dell PowerEdge 2950 (becwfk1_6) Server
My dvd rom will not read my iso image cd for a boot. but it will read factory made cd.. help i need to update my raid controler i have at dell 2950 server running MS2003
    New Friend:
If you have a spare USB flash drive lying around, you could try using http://unetbootin.sourceforge.net/ with the ISO image. Then, hit F11 while the 2950 is booting and you should be able to select the flash drive.
If that doesn't work, see if you can find updated firmware for your DVD-ROM on http://support.dell.com or if it's an aftermarket install go to the OEM's support site.
Failing that, maybe try different media. If you're burning to a CD-R, try a different brand (and avoid CD-RW discs.) If you're using a DVD-R, try a DVD+R.
Posted on Oct 14, 2010
  • reccom Oct 14, 2010
    there's no option to select boot from USB in the boot menu.. I do have the orginal dell install disk but no update ulitity..have you heard why this would be happen to a DVD rom
  • cuncator Oct 15, 2010
    Double check the BIOS, make sure the USB ports are enabled and the USB Flash Drive Emulation is set to auto. See:http://support.dell.com/support/edocs/sy...
    I've heard certain burnable media won't play nice with DVD/CDRW drives without a firmware update, especially if it's an older drive with newer media. Something about the color of the dye used. Have you tried an external CD/DVD drive?
6ya staff
SOURCE:
Cisco Dig-73082 Server Usb Dvd/cd-rom driver download from where?
Cisco doesnt have any file aside from the ISO file that you can download on their website .
2 ways to download and install the driver
1 Download and install an ISO converter software and use or click the link for the driver software
https://software.cisco.com/download/release.html?mdfid=283862063&softwareid=283853158&release=3.0(2h)&relind=AVAILABLE&rellifecycle=&reltype=latest
and use this site to download and install the ISO converter https://www.crystalidea.com/zip-to-iso-converter-convert-zip-archives-to-iso
2. USE window update
Updating the Windows Driver
Perform the following steps to update the LSI MegaSR driver for Windows or to install this driver on an
existing system booted from a standard IDE drive
Step 1 Click Start, point to Settings, and then click Control Panel
Double-click System, click the Hardware tab, and then click Device Manager. Device Manager starts.
Step 2
In Device Manager, double-click SCSI and RAID Controllers, right-click the device for which you are
Step 3
installing the driver, and then click Properties.
On the Driver tab, click Update Driver to open the Update Device Driver wizard, and then follow the
Step 4
wizard instructions to update the driver
Feb 05, 2017 | Cisco Computers & Internet
My dvd rewriteable drive does not read cd discs but only dvds, and it does not burn neither dvd or cd even though i have the proper burning tool.
what sort of burning software are you using it might be because you have not selected to burn data or an iso
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image
that seems strange if it reads dvd's it should read cd's
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jun 20, 2011 | Toshiba Computers & Internet
Need to add drivers and probably need software for lite on combo 4816h- will need to put on flash drive to uploadto my pc.
im not sure what software you want?
erase or format rewritable disc, copy your CD or DVD to ISO image.
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver once you have select update windows will ask where to find the driver and if you want to connect to the internet
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers if your computer came with a motherboard disk the driver could be on it
hope this helps
May 21, 2011 | Lite On LTC-4816H CD-RW/DVD-ROM (Combo)...
How to reset dell mini laptops password to get into computer?
Hello there.
This is quite hard for you but one piece of advise read before initiate it.
First step.
Download this one: http://www.gentoo-portage.com/app-crypt/chntpw
Its an ISO, once its done downloading burn that ISO into any CD/DVD.
After you burn it. Put that CD/DVD into your CD/DVD ROM.
Restart your Computer. Boot from CD.
From there theres alot of option. Just read carefully do as what the hint says. And lastly after you manage to erase your password, After you press "q". Do not forget to save it. Just Press Yes on the last part. After that the CD/DVD will eject automatically.
Hope this helps and please rate.
Sep 24, 2010 | Computers & Internet
Nrg- files , how to open?
you can only open that file and make the icon file visible to your desktop by downloading cd or iso burner through nero, demon or alcohol. because .nrg files is a image extension file generate through software applications cd and iso image burners.
Aug 07, 2010 | Toshiba Computers & Internet
Bootable dvd
Make an ISO image and burn it on a different DVD and you will be able to boot it. make sure the source is bootable.
Jan 04, 2010 | Microsoft Windows Vista Home Premium with...
Trying to set-up striped array. When loading operating system sata drivers are required. Where can I find these
While the computer is booting up from the CD/DVD, you are presented with a message saying: "Press F6 if you need to install a third party SCSI or RAID driver....". If you press F6 at this stage, you will be able to install the required SATA drivers.
Another way is to make an ISO image of your OS installation disc & slipstream your SATA drivers into that ISO image using nLite, then burn the modified ISO image back on a CD/DVD & boot the system using this CD/DVD. This way, you will be able to load the SATA drivers without pressing F6. This will be installed automatically.
Check the following link for more details:
http://www.ehow.com/how_5117088_install-party-scsi-raid-driver.html
You can download nLite at the following link:
http://www.nliteos.com/download.html
After downloading the installer, install the program & start using it.
The following link describes how to use nLite to slipstraem the SATA drivers into the Windows XP installation CD:
http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html
Oct 27, 2009 | Xerox Office Equipment & Supplies
I Wanted To Make a BOOT CD For Windows XP But The Problem is That I Have Windows Vista and i Dont Know What To Do So What Can i Do
How to make a bootable Windows Vista ISO DVD media
  1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
  2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
  3. Exit from the Install Windows screen.
  4. Download CDimage 2.52.
  5. Extract CDimage from CDimage.zip to the C:\ root directory.
  6. Open a command prompt shell, and run the following command: cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
    Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
  7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Visit here for illustrative guide on using CDImage GUI version to make the bootable DVD ISO.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK).
  1. Complete step 1 – 3 as above.
  2. In the command prompt window, run the following command: oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
    A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
  3. Burn the ISO image file by using last step above.
Visit the guide to create Vista bootable DVD using vLite.
Note: For 64-bit Windows Vista, download etfsboot.com and put it into “\Vista\boot” folder. Or users using WAIK (WinPE), the etfsboot.com can be found at %Programfiles%\Windows AIK\Tools\PETools\amd64\boot\ folder. So simply replace -bC:\Vista\boot\etfsboot.com with -bC:\Program Files\Windows AIK\Tools\PETools\amd64\boot\etfsboot.com when making 64-bit Vista DVD image.
Aug 02, 2009 | Computers & Internet
SATA RAID Controller Card Problem?
You are almost there. Go into your BIOS and enable RAID. Then your raid bios should show up on next boot.
Feb 15, 2009 | Intel Motherboard
How to burn an ISO FILE to a cd disk and make it bootable
an iso file is an image of a cd or dvd ...so when you burn it you need to burn it as a disc image.....nero burning rom gives this a one of the options when you go to burn....as far as making it bootable oyu'll need to play around with the ISO (unless of course the image is of a bootable disc)
Dec 20, 2008 | HP Disk drive - CD-RW / DVD-ROM combo -...
Dell PowerEdge 2950 (becwfk1_6) Server Logo
564 people viewed this question
Ekse
Clive
Clive
Alun Cox
