Keep getting this error F3. I tried unplugging for five minutes and reset clock but still get this code. What can I do to solve this problem?
F3 generally means an open temperature sensor send me a chat and I can help you fix it...
if you can get me in a chat I can help you but I will need a model number
Not the whole model number FGF337G two letter missing at the end.
You will need to change the electronic oven control #316455410 and the sensor probe #316233900
F3 is the electronic oven control thinking it has a shorted probe but it may be or the electronic oven control is shorted a part that controls the over probe
you can test the probe but I always change both..
Only two fault codes are displayed by this control - F1 or F3. Generally, F1 display implies the electronic oven control itself has detected an internal
malfunction. F3 implies the control has detected a sensor probe failure. In either case, an alarm will accompany a displayed F1 or F3.
Open RTD sensor probe. Note: The EOC will initially display an F1
for this condition. The EOC thinks a runaway oven condition exists.
2. Shorted RTD sensor probe. Note: The F3 for shorted probe should
only occur when the oven is active or when an attempt is made to
enter a mode.
Check resistance at room temperature and compare to RTD sensor
resistance chart. If resistance does not match the chart, replace RTD
sensor probe.
2. Check resistance at room temperature, if less than 500 ohms, replace
RTD sensor probe
Temperature(°F) Resistance (ohms)
32 ± 1.9 1000 ± 4.0
75 ± 2.5 1091 ± 5.3
250 ± 4.4 1453 ± 8.9
350 ± 5.4 1654 ± 10.8
450 ± 6.9 1852 ± 13.5
550 ± 8.2 2047 ± 15.8
650 ± 9.6 2237 ± 18.5
900 ± 13.6 2697 ± 24.4
Hope this is some help? please let me know
I've replaced both the oven sensor and the igniter with new parts. The oven sensor I replaced was reading open.
Before spending cash check your fuse - if its fine, take a damp cloth and clean the sensor. If this simple solution doesn't work then try the technical stuff.
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Hi - Typically error code F3 indicates a faulty sensor probe or wiring harness between sensor probe and EOC. Try resetting the range by unplugging it or flipping the circuit breaker off for two minutes (this usually will clear most false error codes). Turn on the range and if resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
please fill me in.
Model number I believe is FGF337G
anymore help here? Gave model number. Thanks.
Model number given, hae no idea how to get you in chat. Still need help.
