I have a Kitchen Aid Mixer K45SS. I do not have a manual. What must I do to turn it on? I have moved the lever that said Off to another position and the lock lever is Locked. Please help !
Sincerely,
B. Phipps
Try replacing the moter brushes,if not its probably ether wiring or in the switch board.
SOURCE: KitchenAid Artisan KSM150BOB Stand Mixer won't start
It could be very easy. It maybe you have a the brush in the
wrong way round or they have simply run out. They are on the sides under the black plastic caps. Although they will fit in the hole any one of 4 ways
round, there is a key on one corner which means it will only go in one
direction. Use a torch to look into the hole before you put it back in.
They shoud look like this : brush
THE MIXER RUNS ! SECOND THEN STOPS?
Mixer runs about 10 seconds and stops. Will start again, but will run for only a few seconds before stopping again. Unit is 2 years old and used only one time previously.
mixer will not start at all
