Question about Canon DR-2050C Path-Through Scanner
I keep getting the error: The device could not be locked. Check to see that another application isn't using the device -4630 I can get it to go away if I restart the computer and unplur and replug the scanner. Any thoughts?
  • Akshay Kumar
    Akshay Kumar Dec 29, 2016
    1-Run "services.msc"
    2-Find "Windows Image Acquisition (WIA)" and right-click it
    3-Select "Properties"
    4-Change "Startup Type:" to "Disabled".
    5-Reboot computer
    Akshay
  • Jhon
    Jhon Jan 21, 2019
    Thanks..from @ www.themedove.com
    New Friend:
Uninstall the driver and reinstall the driver. Make sure your driver supports the Operating System you are using.
Posted on Jan 13, 2011
  • 1 more comment
  • Kyle_MIETech Jan 17, 2011
    There maybe a Scan Panel in the lower right hand side next to the taskbar. Check Startup with msconfig and uncheck Scan Panel. Reboot and try it again. I did this and it worked for me.
  • canj2011 Jan 26, 2011
    With the scanner connected to my XP laptop via docking station I ran the setup.exe from the Version 2.3 folder under ISIS-TWAIN for the DR-2050C. I tried scanning and got "device could not be locked" error.
    All I did was disconnect the USB scanner (while it was on) and connect it to another USB port on the docking station and it began to work perfectly.
  • whelanmix
    whelanmix Dec 03, 2012
    THNKS A LOT... WORKING FINE NOW...... WW
6ya staff
SOURCE:
Epson workforce wf-4630 printer what dose the error code 0x97 indicate.
Check our video out on a very similar model. Had error code that your printer is having:
Jan 12, 2017 | Epson WorkForce WF-4630 Wireless Color...
Epson Wf-4630 keeps jamming when i use the ADF to scan documents
You may need to clean the rubber rollers. I have attached videos on how to do so.
How to clean ADF Rollers:
Clear Epson ADF Error:
Nov 04, 2016 | Epson WorkForce WF-4630 Wireless Color...
How do I make the text larger on my office jet 4630 printer
This is the font setting in the application.
Make sure the font is at least 12.
(I am assuming the default settings in the printer setup.)
Oct 25, 2015 | HP Officejet 4630 Inkjet Multifunction...
How do you get rid of the Canon DR-7550C -4630 error "The device could not be locked"?
It's usually a software conflict.
If you have multiple scanning programs, the one of them may have it locked. Especially if you have a scanning program that runs as a service.
Jun 13, 2014 | Canon imageFORMULA DR-7550C - Document...
Download driver fow u.a.u 4500
Question
canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device -4630".
Answer :- change USB cable which is connect with scanner to PC or laptop definitely it will resolve.
By:- shyam shyam.lal@teamcomputers.com 9210845186
Aug 02, 2013 | DigitalPersona UareU 4500 Fingerprint...
I have canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device...
Question
Sep 13, 2011 | Canon DR-2050C Path-Through Scanner
Installed driver twice for Canon DR-2050c. Still
Pls run checkdisc/scandisk on your Comp. Your OS may be corrupted. Just to verify try scanning by connecting to a formatted newly loaded OS Computer.
S. Mohan
Sep 09, 2009 | Canon DR-2580C Path-Through Scanner
I get this: App error 205 / reset - Hour glass keeps running. I removed the battery several times.
If it is application error then follow these steps: Warning: You should not install a version of BlackBerry Device Software that is earlier than the version installed on the BlackBerry smartphone. Doing so could cause the BlackBerry smartphone to malfunction. Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the computer by completing the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications you want to load, and then click Next. Click Advanced, and then select the check boxes beside Erase all application data and Erase all currently installed applications . Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager Note: BlackBerry Desktop Manager 4.3 will display the Delete all application data and Delete all currently installed applications check boxes in step 6 of the above procedure. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Add/Remove Applications. Type your BlackBerry smartphone password and click OK. Select the check boxes next to the names of the applications you want to load. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Click OK. Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager. Note: The Delete all application data and Delete all currently installed applications options are not available when using the Application Loader in BlackBerry Desktop Manager 4.5. A workaround for this issue is to use the Application Loader standalone file by performing the following steps: Open My Computer (or Computer in Windows® Vista?). Navigate to C:\Program Files\Common Files\Research In Motion\AppLoader. Run the Loader.exe file and follow steps 3 through 9 above to complete a clean installation of the BlackBerry Device Software.
May 26, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Canon DR-2050C Path-Through Scanner Logo
27,893 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
