I am using a Epson CX9400Fax with my VoIP phone. I have been able to send faxes, but I cannot receive faxes. I have changed all the settings as advised, except the baud rate. I cann't get Epson to advise: How do I change baud rate to 9600 on CX9400Fax?
If someone can help me, I would be very grateful! I have spent days trying to get an answer on this.
Thanks!
Here's a good place to start..see the user manual at the bottom of this page
This fax speed is 33.6 or 33600
You can change settings to 14.4 or 14400 but not to 9.6 or 9600.
Under: Fax Settings you have this choices:
Speed Dial Setup
Scan and print setup
Communication
Header and time
Under Communication:
DRD
ECM - error correction put this one: off
V.34 - this one is for speed: on - 34400; off - 14400
I found error in my info it should be:Press Setup.
Select Fax Settings, then press OK.
Select Communication, then press OK.
Adjust any of the following settings:
V.34 On (default) - Indicates the speed at which you transmit faxes.
On is 33.6 Kbps and Off 14.4 Kbps.
More info:
ECM On (default) - Indicates whether you use Error Correction Mode to automatically request retransmission of fax data that is received with detected errors.
DRD All (default) - This feature can be used with a Distinctive Ring Service (Detection)provided by your phone company. With this service, you can have two or more phone numbers assigned to the same line, with each number given a distinctive ring. For example, if you have a phone number for personal calls that's set to ring normally (with a single ring) and a fax number set for a double ring, select Double as the DRD setting. Then the fax system picks up only those calls with a double ring.
Rings to Answer - Indicates the number of rings that must occur before the CX9400Fax Series automatically receives a fax. You may want to change this setting if you have connected a telephone or answering machine.
Dial Tone Detection - When this setting is on, the CX9400Fax Series dials automatically when it detects a dial tone. It may not be able to detect a dial tone when connected to a PBX (Private Branch Exchange) or TA (Terminal Adapter) system. In that case, turn this setting off.
I tried the manual and it is not in there. Thanks.
I am having exact problem. Epson seems to ignore the question. I can't believe they ignored a baud rate change in their engineering in this day and age of digital phone lines and Voip? I have taken everystep there is.
Don Scott
The answer is:
It cannot be done!
I finally called Epson and demanded an answer. They were trying to avoid the question again and I told them I didn't need to go through every thing with them again that I only needed an answer to this question. They finally told me that it cannot be done. It only works on their dot matrix. So, I am taking mine back to the store that I bought it and buying one that I can change the baud rate to 9600!
I need help! I can not receive my faxes! Any Idea's?
Epson Stylus CX9400 Photo Printer
dvdpl's solution works SUPERBLY! Thank you so much, it saved us money and time. God Bless you.
