Www.hp.com/support
enter printer model and number and run diagnostics with your printer connected to your PC or Laptop.
SOURCE: hp deskjet D4160
unplug the usb cable.......open printers and faxes........delete the printer icon........click on file........click on server properties.....click on drivers tab........click on Hp Deskjet D4100 series....click on remove........close all the windows........
***** The above is enough to fix the problem *****
SOURCE: PAPER JAM WONT RESET EVEN
On the paper jam ,I tried to pull the ink cartridge over to center. It came over a little & then it jammed up.I noticed the ink cartridge lock tab had popped up & jammed it to the right , once I got the tab back in place the code cleared & it works good now.
SOURCE: HP DeskJet D4160
printed fine and then stopped. now the arrow light is flashing. i unplugged it several times to no avail. what is going on and how do i fix the problem?
SOURCE: HP Deskjet D 4160 Printer quit working after paper jam.
Replace both cartridges, power down and try again. The blinking light stopped and now I'm able to bring. Had gone through powering down four times before doing this.
