Poulan Pro PR550N22SH 22Inch Briggs  Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) () Logo
Posted on Oct 12, 2010
Need to put oil in and don't know what kind of oil to put in or if it's gas oil mix????
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
531
Points
ADD SAE 30 SMALL ENGINE OIL. 18oz TO 20oz
SEARS SALES A 20oz BOTTLE OF CRAFTSMAN SAE 30 OIL FOR $2.59
2answers
What kind of oil does a husky 3000psi pressure washer use?
I don't believe that Husky (Home Depot) makes any 3000psi pressure washer that operates with a 2 Cycle motor. So.... gas only in the gas tank. Husky pumps can be from several differant manufacturers... some use no oil, some are sealed and don't recommend any attempt at oil changes, and some use Non-detergent 30w oil and some use 20-50 Full Synthetic oil. You can look up your specific model specifcations with a google search for Husky pressure washer.
Oct 21, 2012 • Garden
Do i mix the gas or use straight gas
The answer is that ALL 2-stroke engines requires that you mix oil with the gas. ALL 4-stroke engines do not take oil in the gas. So the simple answer is if there is no place to add oil, then you have to mix oil in the gas - not the same kind of oil though! I don't know this particular model, but I have never seen a 4-stroke wearable leaf-blower. The kind on wheels could be either, but most (maybe all) are 4-stroke.
2answers
We have lost the information to make the gas mix for the trimmer. We used the gas mix we had last year and it put out a white exhaust. What is the gas/oil mix?
Hello. First, never use old gas ion a small engine. Use 1gallon of new gas and add one small bottle of mixinng oil, 2 ounces,available at any Walmart or auto parts store.
May 26, 2011 • Garden
2answers
Does a yamaha 2003 atv have four stroke engine?
Do you mix oil into the gas?? Is there a place to check the oil (a dip stick). Is there a special place to put 2 cycle oil for a self mixer?
If you don't mix the gas with oil and there is no special place to put 2 cycle oil, you have a 4 cycle engine.
If there is a place on the side to check the oil level, you have a 4 cycle engine.
Next question will be ... how do I check the transmission oil? If you have a 4 cycle engine, the engine oil is also the transmission oil ... rule of thumb.
You are showing a picture of a motorcycle and asking a question about a ATV, but not mentioning a model number. I don't think Yamaha is currently making a 2 stroke engine for their ATV's (there are several sizes - not including assorted models for sale around the world ... and I don't know where you are writing from (and please don't say).
Maybe the best thing for you to do is call the Yamaha dealer on Monday morning and tell them the model you have and ask the question 2 stroke or 4 stroke. There will be no more guessing on your part then.
Make sense?
Thanks for your question @ FixYa.com
I need to know if I need to mix the gas for my Yamaha 2002 Banshee 350 Twin or if I can just put in straight gas
Normally these days on 2 stroke engines you put fuel into the tank directly and then you should also have a reservoir for your oil mix on the LH side cover. The system will mix the required fuel to oil mix themselves. Good enough?
May 21, 2010 • Motorcycles
4answers
I guess he needs to know what kind of oil he needs also
you shouldn't need to mix oil with gas on a four cycle engine. this is for two strokes.
Aug 23, 2009 • Garden
4helpful
2answers
I dont have the manual and Im not sure what ype of oil I should put on this chain saw. On the left The nob sais oil (which kind?) and on the right side it sais oil/gas mix (which kind?) what do i put on...
The Left knob needs chain oil. Available in most hardware stores. The right is gas mixed with 2 stroke motor oil. Usually a 50:1 mix. Ie. 50 parts gas to 1 part oil. 2 stroke oil comes with a built in measuring tool and directions printed on the bottle.
Jun 03, 2009 • Garden
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
