SOURCE: GE Profile range oven door
foil was just protective heat tape, there is a track across the bottom of door that is holding it up,
SOURCE: Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
SOURCE: Is the glass surface on my GE Spectra solid surface glued to the heat element frame ?
The exterior panel (stainless in my case) is "glued" by adhesive to a lower metal piece which attaches to the door. I know this because my front panel came unglued and there is no other means of support. I am buying a very expensive new front panel.
SOURCE: melted plastic on tempered glass on a gas fireplace
try using a ceramic hob cleaner to get it off
