SOURCE: Error flashing and won't reset.
hi there,
PF stands for power failure. the first you should do is check your house breaker and make sure that you did not trip the fuse.
Does anything run? Can you hear the motor running? If not, you have no power coming into the machine. In this case it's the main control board that needs to be replaced.
If the motor hums, it means you have power to the d/w, in that case you need to replace the touchpad.
thanks
SOURCE: Washing light flashes on Frigidaire FDB1050REM dishwasher
1) Turn off the breaker to the machine.
2) Wait 30 seconds and then turn it back on.
3) All the lights will be flashing. At this point turn the dial to "rinse only" and then press "Heat dry" and "Start/Cancel" at the same time.
4) The Machine will go into maintenance mode going through all the cycles quickly.
5) After this is finished the problem should be solved.
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
SOURCE: 4000 Series Aquasurge diswasher, ER code came up
VO is vent sticking open, in top of tub upper right. You may be able to clean if not replace it.
SOURCE: My Frigidaire dishwasher will not start.
No solution, just a big thanks about that tip on holding down that 'Heat-Dry' button. Worked like a charm.
Thank you for your inquiry, William Garrett!
I understand that the washing light on your Frigidaire dishwasher, FDB1050RES0, continues to blink and will not run. You may need to perform a reset on your dishwasher. In order to do so you would need to disconnect power from your dishwasher for roughly ten minutes. This will help clear out any false error codes or miscommunications within your dishwasher. If resetting your dishwasher does not resolve the issue you may need to have an electrical component replaced and I would recommend seeking professional assistance for that. Hope this is helpful. -Matt
Hello - Try resetting the dishwasher by disconnecting the power to the unit. This will clear most flashing lights. You can disconnect power by flipping the circuit house breaker off and back on for approximately two minutes. If this does not prove to be successful, contact a professional to move forward accurately. Dishwasher could possibly have a faulty control board or wiring failure.
