Re: Hello I have a 2000 neon and when I use the...
The loud buzzing noise means the electric motor that actual unlocks the door has failed or is failing. In order to repair this you need to replace them.
If the door buzzer switch is broken and moving around it will ground out on the door an complete the circuit and cause the buzzer to go off. if you do not want to fix the switch remove the wire from the switch and tape it up with electrical tape
try taking the door panel off and giving all internal works a good oil up with a oil can with engine oil in it not no spray stuff as this dries out because its only fish oil
You need to take off the door panel, and replace the latch assembly which should come with the actuator. If the actuator comes seperatly, you can just replace it for cheaper.
ok ur door lock switch isnt going out,,however ur drivers front door lock actuator is going or is already bad...have that replaced..also as far as the end noise buzz u hear , that may be ur a.b.s modulator and accumulator cycleing on and off..it may be empty and or leaking..have the a.b.s modulator and accumulator checked at the dealer..its an expensive fix... ur modulator unit in in the front left or right of the vehicle depending if u have a v6 or 4 cyl. its a square unit with a rectangular brake fluid resevroir and a long tubular cylinder (acummulator)... also identify it by the orange connectors...and the brakelines going to it...common symptom with those accords....they leak alot especially if with high mileage..
