Connect your TV to a DVD player. If there is still no picture, it means the display inverter of your Tv is defective.
The display inverter is what makes the TV brings picture. Since the TV
is no longer bringng any picture, the display inverter is the first
thing that needs to be checked as it is most likely the cause of the
problem.
Please give me feedback if you need any assistance in locating or identifying the display inverter.
The display inverter is what makes the TV brings picture. Since the TV is no longer bringng any picture, the display inverter is the first thing that needs to be checked as it is most likely the cause of the problem.
Hi, it could be bad inverters or a bad power supply. I'd inspect both boards. you should have 24 volts coming from the power supply to the inverter. If you have the 24 volts, bad inverter. If you don't have the 24 volts, bad power supply.
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
Tv turn on now,u only have a flashes of a picture for a few sec. than died have sound left ony?Yes,the tv have 2 long boards call the LCD inverter boards,one on it left and one on it right sides.These 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD picture screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
The tv have a long board call a LCD inverter board.This long LCD inverter board is dead,that why u have picture flashes few min than dies,have sound left only.The long LCD inverter board help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Ur LCD inverter board is dead.This LCD inverter board provide the backlight for LCD panel screen to get a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a reburbish LCD inverter board for the replacement.This LCD inverter board is a long board in shape form.
Ur LCD inverter backlight board is dead.U have to replaced this LCD inverter board to get ur picture back.It a long board in shape.Tries Shopjimmy.com,Ebay.com to buy a reburbish LCD inverter board for the replacement.
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter baklight board for the replacement.It a long board in shape.
Ur LCD inverter backlight board is dead.Replaced this inverter board.U will get ur picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish inverter board.It a long board in shape.
