Question about Necchi 3102 Mechanical Sewing Machine
I just bought an old Pfaff 206 and the machine sews about ten stitches before it just completely jams. I double checked the threading, and the bobbin, both are correct. (I'm sorry I don't know the correct terminology, I will try to be descriptive.) I watched underneath as I turned the wheel to let the needle down, and each time the needle descended the top thread was getting caught on a sharp point (part of the bobbin holder area). I took off the outer plate that holds the semi-circular inner ring in place, and tried multiple times to reinsert the semi circle with the sharp point, but each time the machine's rotational timing is just such that the thread loops around the sharp point and gets carried forward until everything jams and even the needle cannot be extracted (when sewing fabric). I can't think of anything to do that would change this timing: do I need to take the machine to a specialist? I'd appreciate any advice as this is really a lovely machine and I'm looking forward to using it. Thanks in advance!
  • Necchi Master
  • 7,365 Answers
Since you bought it used, if it is timing then a service tech can fix the problem.
& also since it is used having it serviced will give you peace of mind that everything is working correctly.
also after it's serviced, let them sew on it in your presence so you can see it's working properly, after all your paying for it to be fixed, & you should be allowed to see them sew on it after it's serviced.
Posted on Oct 11, 2010
6ya staff
SOURCE:
My pfaff2044 started sewing uneven stitches. It can sew nice then next second leave a big stretch then sew normal again and then itll leave a bigger stretch it also wont blind stitch.
3 Common Sewing Machine Problems (and How to Fix Them)
www.marthastewart.com/.../common-sewing-machine-rep...
Martha StewartSep 26, 2014 - We consulted Becky Hanson of Singer Sewing Company for her tips on ... The Problem: Stitches are coming out uneven or skipping entirely.
Basic Sewing Machine Troubleshooting - Sewing School
sewingschool.org/2011/03/16/basic-sewing-machine-troubleshooting/
Mar 16, 2011 - The thread breaks, my needle bends, or skipped stitches - UGH! Don't get ... Problem: My stitches are uneven and sometimes skipping!
My stitches are coming out uneven - SewingSupport.com
www.sewingsupport.com/sewing.../sewingsupport.../sewing.../my-stitches...
What to do if the stitches from your sewing machine are coming out uneven. Sewingmachine troubleshooting guide.
Dec 12, 2015 | Sewing Machines
My pfaff 4.2 keeps saying remove thread jam under the stitch plate. I have cleared everything several times but it keeps coming up on the screen.
Candace, while not familiar with the 4.2, I've had thread jams on my trusty old Pfaff. I hope this helps!
If you are able to totally remove the bobbin cover/stitch plate, please do so. Ideally, there will be one or two screws holding it in place.
remove the bobbin
carefully inspect the bobbin housing; thread likes to hide behind the housing. If you find some thread, use a tweezers to remove it.
If no thread is found, see if there are one or two screws holding the bobbin holder/raceway in place, or just a lever. Try to remove the bobbin holder, carefully noting what the orientation is of all pieces is (using a cellphone to capture pictures of before and after is great!).
Clear any threads from the raceway, carefully re-assemble everything, test and good luck!!!
Apr 22, 2015 | PfaFF Sewing Machines
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
Needle continually unthreads itself
I would suggest to you to change the needle--it could be damaged
causing the thread to be cut.
also check the needle plate for burrs or sharp spots that you can feel
with your finger.
Nov 07, 2012 | PfaFF Sewing Machines
Message remove thread jam under the stitch plate keeps appearing! It's clean!
After cleaning out the bobbin area, re-threading the top thread, turning my Pfaff 4.2 off and on it still said " remove thread jam under the the stitch plate". I pushed the "ok" button and it started working again.
Keeping my fingers crossed.
Aug 13, 2012 | Pfaff Creative 4.0 Sewing Machnie
Pfaff 7530/ electronic problem?
Where has it been for ten years? This could have a big affect on an electronic sewing machine.
Take the machine in to a sewing machine shop for service.
Feb 22, 2010 | PfaFF Sewing Machines
My Pfaff 7550 sewing machine will ball-up thread on underside
Make sure your tension is set on 5 and you don't have dirt stuck in your tension unit.
Jan 18, 2010 | Sewing Machines
No stitch happening
May sure you are using the correct size of needle and thread suitable for the fabric. make sure the thread in the bobbin and the needle is of the same weight or size. Make sure the needle is changed often - after the completion of an garment. After much use the needles become blunt and cause problems with your stitches.
Also, if the bobbin is jamming that is normally because the machine is threaded incorrectly, or the bobbin case thread is wound unevenly, or the bobbin case is not put in properly.
Try this! Just stop for a while, give yourself a few minutes to relax. When you return pull the User's Manual and slowly go over the instructions, especially the "troubleshooting" section. Also, rethread the machine and the bobbin case by carefully following the steps in your User Manual. I have found that it helps me tremendously when I have problems. Hope it help. Happy Sewing
I have similar problems
Aug 02, 2009 | Janome 8080 Computerized Sewing Machine
Necchi 3102 Mechanical Sewing Machine Logo
256 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
