My television screen is not converging on blue only. i go to menu and perform the auto convergence mode. colors red and green go through convergence mode where the color blocks go around the screen but when it comes to blue convergence one square comes up in top left hand corner screen goes blank then goes back to menu. i then converge the red &blue crosses but color &picture are still out of whack
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
I have the same problem. When I try to auto converge in the menu, I get a dark red screen, and then it's back to a regular display with not convergence. This all started after I had the tv repaired and the warranty is up.
i have a 50 inch rca rear projection and blue will not converge. tried auto converge but it stops when it reaches blue
Same thing. Had the tv for about 2 years or so, and all of a sudden the blue convergence was out of whack.It was working this morning for 20 minutes or so until I turned it off. When I turned it back on, same thing. Also, during autoconverge red and green go fine but when it gets to blue it starts and then fails
