My 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
VALVE LASH NEEDS ADJUSTED AND CHECK ROCKER ARM BOLTS FOR TIGHTNESS. CONSULT KOHLER FOR PROPER TORQUE ON BOLT AND VALVE CLEARANCE BEFORE CRANKING UP ENGINE.
15.5 hp engine stops running and now will not start. when trying to start the engine it back fires through the carb.
