Unfortunately, it is not possible to mount Minolta lenses on a Pentax K mount camera and retain either auto-focus, metering, or the ability to focus at infinity.
The reason for the loss of the ability to focus at infinity is because the distance from the mount to where the image forms on a Minolat lens is 43mm, whereas on a Pentax it is 46mm, so the Minolta lens glass would need to be 2mm into the body of the Pentax camera in order for the image to form on the sensor (i.e. have a clear image that is in focus).
The only solution to this is to purchase an adapter with an optical element such as this:
http://photo-adapter-llc.amazonwebstore.com/Zykkor-Minolta-MD-Lens-to-Pentax/M/B004PB8142.htm?traffic_src=froogle&utm_medium=CSE&utm_source=froogle
This will allow you to focus at infinity, however you will have to use stop down metering and manual focus, as the electrical contacts will not connect. Also, you can expect a slight loss of image quality when using an adapter.
I personally have a few Minolta lenses that I have wanted to use on my Pentax, so I understand your pain. It is a shame they don't work better.
Thank you for using FixYa!
How can I change Image ratios
